cybernck
[project] 205 Mi32 Project - The Twin Mi16 Engined 205
Hilgie
I guess it stopped working when Nick pulled the fueltank out :)
Clarre
hmm i don't know, but that's a good question.
hydraulic handbrake conversions would probably get a bit cheaper if we new ;).
That is exactly what I thought. So anyone who knows??
Come on maybee a Volvo PV 544, what I can remember
on these cars the master cylinder was mounted behind
the brake pedal. And I can hardly think that they have
noting else than a one way ( I don't know what's the name)
but not a two wy system as newer cars. I hope you understand
what I mean.
cybernck
pugtorque & Hilgie> hehe yeah, fuel tank and fuel pump are out and will
be replaced by a custom aluminium tank and external 405 fuel pump,
which has to be wired in, new fuel lines plumbed in... and the enigne
hasn't ran for several months. and that's after the new large radiator
and exhausts get installed... so you'll be looking at a few more phases
before the beast hits the road, in any form :DB).
Clarre> yeah i understand, you mean a sinle outlet port instead of 2/3/4.
it also has to be very small, 0.625" which is about 16mm. we actually tried
to make a hydraulic handbrake many years ago, using a 1.6 master cylinder
with 2 ports blanked (so there's only one outlet). we blocked the rear brake
lines going from the car's master cylinder and connected the rear brakes
only to the 1.6 m/c that has had it's own reservoir. it didn't work out though,
not even with the servo installed (but it was a funny sight anyway ;)).
findlay
Still an awesome build and startling progress :unsure:
One radiator? :( Wow - I'd have thought that possibly two independent radiators may have offered another alternative with ducting run from perspex rear quarter windows, back to a rad located near the back engine.
The early Elises used to suffer from thermo-shock issues for that reason, the radiator was mounted so far away that the coolant circuit would open, the very cold radiator coolant would rush into the engine, meet the thermostat housing and shut the thermostat at which point the process was repeated... again and again. It was not a steady flow of coolant mixture around the engine & radiator. I'd be concerned that having two engines (one fully enclosed in the back of the car) would compromise the viability of a single cooling system.
However I appreciate, Nick, that you have not gone the space-frame route and that with the exhaust manifold being at the very rear of the car, mountin a radiator with a fan isn't really an option there and, I'd imagine, to mount it in the normal loaction of the XS front end would probably mean it is too far forward to benefit from an airflow from the rear quarter windows or a scoop mounted forward of there...
Awesome build though :(
I think Findlay has a point, I'd try to use two radiators. One for each engine & have a thermo switch for a fan on the rear engine so it switches on when the engine is running at the desired temperature swapping to higher speed when the temp hits another preset temperature.
You could take the heater out then as it'd be plenty warm enough inside then. :)
Graham.
cybernck
well we had gone for a single large radiator (and all the problems that go with it) for now, but we'll see...
it's not possible to duct anything from the rear qtr windows, as the engine will be enclosed like in a Clio V6.
side openings are small and one is for the airfilter while the other is for a little bit of airflow in the rear engine bay.
there's no space in front of the engine either, as the fuel tank will sit there and take all the space.
so maybe only behind the engine, with fans drawing air in through the slated tailgate, but not sure how effective would that be?
thanks.
stewy_pug
Dust the grinder off...
cybernck
gay pics :rolleyes::blink:.
that's an intercooler though, not a radiator.
what car is it anyway, looks like a nova?
Grim.Badger
BTW do you know what cars who use the Girling 625
Master cylinder?
Girling are owned by TRW at the moment and I have asked them, but I don't expect a response.
So far I've found out:
Hillman Imps
Land Rovers (maybe just the 1970s ones)
(Triumph?) Spitfires
TR7s and TR8s
AH Sprite and MG Midget
I think they mostly use them as clutch MCs, not sure if that's useful or not.
Henry Yorke
Onthe rad question, what about 2 smaller rads? You could have different thermostats in them to negate the thermo shock effect so they kick in in series, not parallel
Alastairh
Couple of ideas.
the way a guy in PPC did it with a Alfa 155 although its a saloon, he mounted it on the boot, with vents there.
Or the way i remember seeing a Mk1 fiesta at a ford show mounted it just behind the front seats with cool air from below.
Alastair
C_W
Stick the back radiator in the roof with a small scoop covering it!!
tom_m
more pictures more pictures ;)
findlay
And hope that the sysyem doesn't leak! That might create pressure in the engine while its sat idle... That might not be too good for head gaskets etc... Centre of Gravity too - although granted not so important on a 1/4mile car.
TB_205GTI
I can see in your pictures that ypu intend to have a lever to cut off the clutch hydraulics to the rear engine if you only need to run the front one - but what will you do about the rear gearbox then? As I see it, you have welded the shifters for both front and rear together.. If yu plan on occasionally only using the front engine, you need to be able to leave the rear engine in neutral- and shift gears on the front engine ;) have you thought about that ;)
Edited by TB_205GTI
cybernck
As I see it, you have welded the shifters for both front and rear together.. If yu plan on occasionally only using the front engine, you need to be able to leave the rear engine in neutral- and shift gears on the front engine have you thought about that
rear gearshift linkages can be seperate in a few places, now you mentioned it, but it doesn't matter.
it takes only 10 secs to pop one or both short rear gearbox rods off and have only front-engine shifting action :D.
we're going to make it switchable from driver's seat though, later.
cybernck
sorry for the long delay, due to a computer crash, data loss and recovery and
system reinstallation on top of having a lot of commercial design work to do!
Phase 4: Coolant Radiator & Exhaust System
Phase 4 story is all about fitting a large customised radiator:
and constructing both front and rear engine exhaust systems:
so we could start the front engine next.
you can find the story (with 40 pics) on THIS PAGE.
this time it only took three full days of intensive work to complete the phase :D.
stay tuned for a short video and then Phase 5 of the 205 Mi32 Project!
thanks.
cybernck
after completing front engine's cooling and exhaust systems, we hard-wired an external
405 fuel pump to start the front engine after several months of being out of use...
it started without problems, apart from expected noisy hydraulic lifters.
205 Mi32 :: video #001 :: Starting the front Mi16 engine
thanks.
Looking good. B):)
Thats one hell of a death rattle though, hope it fades away.
Has the head been apart or is it just from being stood so long that the oil has drained out of the lifters? ;)
Graham.
cybernck
yeah as i said, it had been stood for several months, so noisy tappets were the least we expected.
oh and the rest of the noise is exhaust manifold related.
the tappets have quitened down since btw ;).
cybernck
Phase 5: Rear Engine Electricity & Cooling
this is the first part of the Phase 5 story, where we tackle rear engine's wiring:
and start plumbing the coolant pipes from the radiator towards the rear engine:
you can find the first part of the story (with 25 pics) on THIS PAGE.
stay tuned for the second part of the Phase 5 story!
thanks.
DrSarty
Keep going dude - not far now.
As for your first picture at Bos Gradiska (spelling?) - sorry about the clutch by the way - I used to drive over the Hungarian engineers' rickety old bridge there and on into Croatia before that shiny new bridge was built in 2000. How time flies! :unsure:
DrS :lol:
cybernck
well you seem to have a pretty good memory :lol:.
the bridge has a rather nasty pothole in an awkward place btw :unsure:.
Rippthrough
Hillman Imps
TR7s and TR8s
I've just checked - my truimph gt6 (similar to spitfire) has a pair - one brake, one clutch.
cybernck
in the second part of the Phase 5 story, we continue work on rear engine's coolant system:
and after testing the wiring and all the sensors, we get the engine started:
you can find the 2nd part of the story (with another 25 pics) on THIS PAGE.
with work being spread over a few months, Phase 5 is finally complete!
stay tuned for an exciting video of starting the rear engine! <_<
i want to wish all the members of this forum a happy and successful new year
in health, love, business and ofcourse... 205's! <_<
thanks.
