SPGTi
Wideband O2 Kit
Rippthrough
Which one do you have?
LC-1
SPGTi
If there's 3 or more wanting the innovate one (same as mine) we can get it for £135 delivered to the doorstep. The good thing about the innovate on is they already have a wide userbase and the technical support is great. You can also hook it up to a laptop for realtime logging, and it has two programmable analog outputs, so you can use it with a stock or an aftermarket ECU, and have a seperatly programmed output for a gauge.
more info on the innovate wideband here
That's without the display though. All I want at the moment is a setup that I can put in the car that will help down the rolling road and when funds allow I can then connect up to an aftermarket engine management. I will try and create a comparison table between the various systems with prices (group buy ) in it.
Steve
Rippthrough
Steve
You should be able to use any display you like with it, but yes, you have to factor it in on top.
Personally I just take the laptop out any time I make any changes and run the display and log the session at the same time.
There's a build your own controller through megasquirt available, but the calibration process is a bit involved to say the least!
Edited by Rippthrough
