RHULPUG
Rev Counter Not Working.....
Jonmurgie
Emerald do one for their ECU (probably same required for Omex), you can download the wiring from their site.
Sorry to drag this back up but where is this wiring downloadable from the Emerald site, I can't spot it?!
Am going to see if the diode trick works with my setup as I kind of need the RPM's cause I don't know how far I can rev the car, plus when your getting noise checked at trackdays they ask you to hold the revs at 4k!
DrSeuss
I've looked into how various options work. IvarS posted the simplest method which is where you use the rev counter output to trigger a mosfet switch. This grounds a coil and you hook the rev counter up to the coil as it is on the 205.
Its the simplest method of getting around it without spending mega money. Spoox charging 70 quid is a piss take.
The other option is to convert the clocks themselves, this is the option i've chosen.
Revla
Hi,
This was the wiring I was refering to:
http://www.emeraldm3d.com/M3DK_manual_v5.pdf
Not that it shows the rev counter convertor... ooops! It comes with the unit when you buy it from memory...
As for £70 from spoox.... I remember paying £35ish last year from there! :excl:
Trev
