Dutch205er 0 Posted September 20 Hello, I drive a 205 GTI with TCT engine for 3 years, now the outside CV joint on the left is broken. Bought another driveshaft, then I noticed it didn't fit in the gearbox.. I don't know what box i have, i do know it has an stronger dif. Therefore, the inside spline has been made longer. Then i tried to put the outer CV on the old driveshaft, BUT: Mine is 21mm thick, the new one is 18 mm.. What outer CV joint do i need? Share this post Link to post Share on other sites
SRDT 252 Posted Sunday at 10:27 PM Aftermarket driveshafts can be a mess. You just buy a part that fits, what's inside and how long it will last that's another story. Here is more about the two diff sizes and also drive shafts: Share this post Link to post Share on other sites
Dutch205er 0 Posted Monday at 01:50 PM Thanks! What a mess with those driveshafts! There are almost no aftermarket ones left,, Share this post Link to post Share on other sites
Dutch205er 0 Posted 2 hours ago Still not able to find the correct driveshaft.. I brought the broken one to a company who will fix the problem. I had the head worked on after a leaking head gasket. Yesterday first start after reassembling, the engine is ticking like crazy.. Did the revision company did mix parts? Now i have to measure and adjust the shims. Might as well throw in a DKZ camshaft, there is one for sale. But the caps? aren't numbered. Will this be an issue? So first the old one out, new one in, measure, adjust the shims. Is this correct? Can't upload here, so put it on YT: XU10j2TE ticking.mp4 i Share this post Link to post Share on other sites
