K20205 5 Posted November 23, 2020 I think i might have found the problem, i managed to get both sides at same height, i left the torsion bars loose and put the car on its own weight, now the rear has some bounce to it. i jacked the car up and tightened everything up and when its back down its the same again?! I then loosened the torsion bar adjuster nuts and when the car is down its got movement again,? Am i tightening the adjuster too much? Is there a clearance problem; does the arms need to be set at a specific clearance? thanks Share this post Link to post Share on other sites
jord294 87 Posted November 23, 2020 There is a reason for double ended stud. When set correctly it allows a touch of 'float' between seal lip and trailing arm. Share this post Link to post Share on other sites
K20205 5 Posted November 23, 2020 16 minutes ago, jord294 said: There is a reason for double ended stud. When set correctly it allows a touch of 'float' between seal lip and trailing arm. So how can i set this right? whats needs doing? Share this post Link to post Share on other sites
petert 554 Posted November 23, 2020 Wind the stud all the way out until it touches the cup, then back it off half a turn. Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted November 23, 2020 59 minutes ago, petert said: Wind the stud all the way out until it touches the cup, then back it off half a turn. Pete, check your junk mail again mate Share this post Link to post Share on other sites
Ozymandis 96 Posted November 24, 2020 I suggest You read the axle refurbishment and height adjustment guides on this website, every single question You have asked is covered in those. If Your still having problems then, for Yours and public safety, best leave it alone and get someone familiar with the technology to do the job? 1 Share this post Link to post Share on other sites
welshpug 1,626 Posted November 24, 2020 read this from step 13 onwards. Share this post Link to post Share on other sites
K20205 5 Posted November 24, 2020 2 hours ago, welshpug said: read this from step 13 onwards. Cheers for that mate, just read it and i understand now, i thought you just hand tighten the stud all the way in and when the bar is pushed into position and tightened on the washer side you just tighten up the bolt, this caused the arm to go in to too much. i read on another forum that i need to use a feeler gauge set at 0.05 and tighten accordingly to that? Share this post Link to post Share on other sites
welshpug 1,626 Posted November 24, 2020 that is correct yes, as shown in the thread there in the first line of point 13 Share this post Link to post Share on other sites
K20205 5 Posted November 25, 2020 17 hours ago, welshpug said: that is correct yes, as shown in the thread there in the first line of point 13 All done, thanks alot mate.. will never be touching the rear end of this car again.! Share this post Link to post Share on other sites
