robdesmond
Oil pressure sender location
robdesmond
Hello All,
Hopefully a very simple question about my 1992 1.9 GTI standard engine. My oil pressure gauge is dead as a dodo but the warning light is fine. Can someone tell me where it lives? Somewhere under the inlet manifold I think? I suspect dodgy wiring as almost every other connection has been chopped and hacked together. Seems a prior owner found ripping the engine without disconnecting anything is possible.
Kind regards,
Rob
PhilNW
The sender and switch are under the inlet manifold. Removing the alternator should give you enough access to them
Google 205 gti oil pressure sensor should give pics as to what it looks like
Edited by PhilNW
robdesmond
Thank you Phil.
