lemmingzappa
1990 205 Gti 2.0 8V Turbo Conversion (Xu10J2Te)
lemmingzappa
Photo%2023-06-2015%2019%2036%2057_zps7jw
Time to fit this new solid fork mount, don't have access to a press or removal tools so I went ahead and used a 30mm hole saw and then pushed the new one in with some grease and a vice.
Photo%2001-07-2015%2012%2007%2040_zpsdgp
Photo%2001-07-2015%2012%2015%2038_zpsbag
The SRi/BX box I'm using had a selector arm fitted which I wouldn't be able to use. Drove the pin out using a punch and pulled the old arm away, be sure to have the box upside down at this point so nothing falls inside.
Photo%2001-07-2015%2012%2018%2052_zps76j
Photo%2001-07-2015%2012%2050%2018_zpshbg
Correct arm taken from another GTi BE3 box now fitted.
Photo%2009-07-2015%2017%2058%2040_zpsdsy
New genuine plugs and speedo drive seal for the box. Not sure if I will be using the reverse switch yet.
Photo%2009-07-2015%2018%2030%2046_zps4uj
Removed the old drive shaft seal (PITA, wish I knew a quicker and cleaner way of removing these).
Photo%2009-07-2015%2018%2030%2053_zpsgfl
Photo%2009-07-2015%2018%2035%2031_zps2dh
New seal fitted!
Photo%2009-07-2015%2018%2038%2007_zpsspt
Time to swap the speed sensor over to the 3-pin dual type. I first removed the speedo drive cog from the existing setup.
Photo%2009-07-2015%2018%2039%2016_zpsbcm
Then pushed into the new dual unit.
Photo%2009-07-2015%2018%2043%2023_zpswif
Ready to go!
Photo%2010-07-2015%2009%2014%2038_zpsuvw
Got myself a brand new genuine VAG '710N' recirc valve. The latest version to date is the '710P' which is used on the Audi RS6, but these are unable to hold boost as well as the N versions.
Photo%2010-07-2015%2018%2008%2022_zpsul7
Next I noticed this ring on the end of the crank, wasn't sure if the BE3 input shaft would fit inside this. Possible only something found on the auto turbo blocks.
Photo%2010-07-2015%2017%2051%2044_zps0ah
Definitely not, as the input shaft is around 15mm.
Photo%2010-07-2015%2018%2010%2034_zpsvhk
Luckily these are easy to remove with a screwdriver as they are made of plastic!
Photo%2010-07-2015%2018%2052%2007_zpsczz
Went to fit the clutch and pressure plate and made the silly mistake of over-tightening the bolts, which then sheared off inside the flywheel.
Photo%2011-07-2015%2010%2008%2017_zpsekp
Luckily I was able to remove this by drilling a 3mm pilot hole and hammered a 4mm allen key in, then remove by hand.
Slo
pain in the fkin ass them flywheel bolts i popped 3 tightening mine up they feel so loose then doof.
how much was the plastic dump valve, farmer got me a new original unit out of thin air, they work so much better than after market crap
lemmingzappa
Yea that's the same feeling I got when tightening.
I got the recirc for £25 delivered from Germany.
estland
Very cool project. Looking forward for an update :)
lemmingzappa
Final coolant plumbing diagram.
Photo%2015-07-2015%2013%2012%2012_zpscpy
63mm > 60mm reducer (turbo to intake pipework) & high tensile m7 bolts for the clutch cover.
Photo%2020-07-2015%2013%2010%2020_zpsudt
The plan is to run this on the intake pipework to dump the recirc'd air back in, near the turbo.
Photo%2022-07-2015%2013%2024%2023_zpsnjx
FPR blue vacuum. I'll get round to the other vac hoses once the engine is in the car.
Photo%2022-07-2015%2017%2055%2058_zps18v
This bracket on the dipstick tube holds the oil filler tower in place. Unfortunately the lower silicone hose now catches on this as it's thicker than the original pipework.
Photo%2022-07-2015%2018%2017%2005_zpstmq
Easy to resolve with some cutting and smoothing, using a dremel. Then touched up with black paint to protect the metal.
Photo%2022-07-2015%2020%2048%2059_zps2ov
Got round to configuring the VEMS 'Round' AFR/EGT gauge. I won't be using the narrowband output until I run aftermarket management. AFR showing between 14-15 when holding in the tailpipe of another car, so I'm fairly confident it will read ok.
Photo%2022-07-2015%2020%2052%2048_zpsgbu
Configuring the EGT sensor using ice and boiling water. I'm now seeing 100 degrees between the two and will need to use the correct offset to show 0 on ice.
Photo%2022-07-2015%2021%2023%2033_zps89v
Figured out my ideal calibration (specific to each sensor and gauge). Burn to ECU!
Kezzer30
Looking at this with interest as I wanted to do this for my next project but being told the wiring is an absolute pain to sort etc .
Daviewonder
Wiring is probably one of the easiest parts of the conversion.
Slo
Having been at this point myself i agree its really simple once you have worked out which wires you dont need rather than what you do need, that said having wire numbers and a diagram to work from makes it even simpler but mine is the old style management and needs the keypad plugged in it wont run without it
johniban
Really like this project, nice attention to detail
estland
Any progress? :)
Its all in the car largely ready to go and looking pretty good... other than the wiring loom which is currently spread over my living room floor while I finish off converting it for him.
Those saying it was easy I'm assuming didn't start with an XM loom. The basic connections to make it work in a 205 are easy enough, but nothing is in the right place for fitting into a 205 (atleast how Josh has done it anyway) and needs relocating/lengthening/shortening to fit. Its an utter ballache to do nicely compared to Mi16 and GTi6 looms IMO!
Still, he'll have it back this month as his Xmas present :)
lemmingzappa
I ran out of free time to keep this thread up to date unfortunately but as Ant has said it's pretty much ready to go, just a few small bits here and there remain. Very much looking forward to receiving the loom and giving the key that first turn!
Will be without an exhaust to begin with, but I'll be happy to get it started to be honest. I'll post vids/pics once that happens.
I suspect that your neighbours won't be quite so happy... :P
Looking good, not read it all but the speedo will be out with a black gear on the pick up, should be white/cream and red
lemmingzappa
Thanks for letting me know. The black one was removed from my 1.6 box, I presume I need to source a red gear from a 1.9 unit?
1.6 should have a red cog too.
lemmingzappa
Gosh, I guess I've been using the wrong one throughout my entire 205 ownership then. Any idea where the black ones come from?
306's iirc
lemmingzappa
Edited by lemmingzappa
lemmingzappa
Ok so over a week ago the car had its first proper start, no exhaust fitted as of yet but that is due very soon! Seems happy enough idling & revving a small amount,
Hope to have it MOT'd this month, providing I can stop my brake flares leaking.
Huge thanks to Ant for the loom conversion! More videos to come.
j_turnell
Happy days, looks like a tidy install too, good work.
Excellent, just need some dry roads now :)
Slo
You wont be saying that when you see the temp go up lol. Looking good zappa whats your 0-60 time it should be around 6 seconds :D
