lemmingzappa
1990 205 Gti 2.0 8V Turbo Conversion (Xu10J2Te)
lemmingzappa
1175513_10151778785622311_799732843_n_zp
Finally time to put another engine in the 205 after the bottom end let go on my previous 8v. This time I'm going for a 2.0 8v Turbo conversion and it's the first time I've ever attempted anything like this. It will be interesting to say the least!
I picked up an XU10J2TE from Jackherer, which was apparently removed from an Auto XM Estate:
Photo%2021-03-2015%2014%2008%2029_zpspgt
I've started by trying to make note of what goes where and as I've never owned a boosted car before some of the parts are alien to me. Slowly getting there though! Now to start cleaning the grubby bits:
Off comes the throttle body:
Photo%2013-04-2015%2019%2025%2047_zpsplf
That's better!
Photo%2015-04-2015%2023%2001%2022_zpsnyu
Removed one of the factory boost pipes, gave it a good degreasing, masked up and then tarted it up with some silver high temp paint:
Photo%2015-04-2015%2019%2021%2032_zpsedh
The inlet manifold was a bit crusty and wanted to do the same with this too. The black bracket and throttle wheel were in the way so decided to remove the circlip (7mm) from the top of the wheel and slide the spring off. The rest of the bracket comes off in one piece but requires some yanking force! I couldn't get the circlip off without breaking it so this will need replacing when it goes back together:
Photo%2017-04-2015%2018%2001%2003_zps77l
Photo%2017-04-2015%2021%2043%2002_zpso1y
I took a wire brush drill attachment set to the manifold and ground off all the grime, it handy having different shapes and sizes to get into all the corners:
Photo%2018-04-2015%2013%2057%2059_zpsrpb
Photo%2018-04-2015%2013%2057%2050_zpsnp3
The insides were a bit coked up so I used some Mr Muscle oven cleaner (foaming spray) which would expand inside and eat away at the dirt. The can states that you shouldn't use it on aluminium but this isn't an oven and I would probably never end up doing this again anyway:
Photo%2018-04-2015%2014%2000%2045_zpscuz
I thoroughly jet washed the foam out and the results were quite good. If you wanted it to be perfect I would recommend repeating the whole process a second time but I didn't want to expose the bare metal to chemicals and water for too long:
Photo%2018-04-2015%2014%2051%2038_zpsqmi
Photo%2018-04-2015%2014%2052%2014_zpstjk
I've already dried out the manifold, masked it up and applied two layers of high temp paint. I'll post pictures after the painting is finished. I have bought a load of service parts for the engine and some extras such as this Sierra Cossie 2WD intercooler:
Photo%2026-03-2015%2014%2014%2026_zpsxtp
Good work, that's looking a lot better!
Slo
You can buy a brand new throttle body on ebay atm (ive got one). They have got them up at £49.99 buy it now or best offer. I offered them £20 twice and they accepted. It even comes with a new throttle switch that is now nfp and retails at £143 alone so got to be worth it for the throttle switch by itself not to mention an airtight butterfly.
Good luck with the conversion its a lot of work but the boost is something else and worth doing properly and spending the money to get it right.
lemmingzappa
Thanks for the heads up Slo, the seller wouldn't accept less than £35 but still a good deal! I'll be running the standard management for now so nothing crazy.
Slo
Did you re offer them £20 like i did? they counter offered 39.99 the first time and accepted 20 the 2nd time. Nevermind even at £35 its a cracking saving over retail :)
lemmingzappa
I did and they countered with £42.99, then £39.99.
lemmingzappa
Progress is slow as we have a new baby girl to look after, but I'm doing what I can with whatever daylight is available after work. Here's what I've been up to since last time.
Finished painting the inlet manifold:
Photo%2023-04-2015%2019%2013%2020_zpsz9x
The bracket which sits on top of the manifold is usually black, mine also had some corrosion. Whilst fixing it up I thought I'd spray it the same as the other parts to match:
Photo%2022-04-2015%2018%2010%2057_zps4i4
Ground back:
Photo%2023-04-2015%2018%2016%2036_zpslwp
One layer of paint complete:
Photo%2023-04-2015%2021%2031%2053_zpsocu
Whilst taking the upper timing belt cover off the engine these fell off the back of the block somewhere. I had no idea they were there and not sure if they were holding something together or not!?
Photo%2020-04-2015%2019%2024%2012_zpsel8
Off comes the loom:
Photo%2021-04-2015%2018%2051%2050_zps3m7
Pulled the engine mount and a few other bits off, slowly getting there. Want to get it as naked as possible ready to clean up and paint:
Photo%2021-04-2015%2018%2059%2058_zpst6h
Old throttle body vs brand new:
Photo%2022-04-2015%2013%2030%2015_zpsppr
Time to start grinding back the Mi16 engine mount:
Photo%2023-04-2015%2018%2048%2011_zpsowg
Slo
What are you chopping off the engine mount? I had to use the cast iron mount from a gti6 as the mi mount made the engine sit cock eyed plus i wanted pas too and its very neatly compacted compared to the old system that the original mount had and that 2 belt bottom pulley.
That throttle body :wub:
Err is it only me who can see the hole spacing to attach it to the nanifold is drastically different? Look at the lower mount hole.
jist the angle of the picture I think.
Before I cleared my garage out there was a whole layer of other stuff on top of that engine and that tool must have fallen out of a box and ended up on your engine. It definitely wasn't holding anything together :lol:
cheesegrater
Josh if you need a '6 mount I have a few kicking about.
lemmingzappa
No chopping, just grinding and painting.
Just the angle of the pic, I did have to double check though ;)
Cheers, hopefully I'll be OK with the Mi one but I will keep that in mind!
lemmingzappa
One of the ball pins on the throttle linkage was damaged due to corrosion. After I popped off the original plastic ball joint it would not go back on and kept popping off. The same happened with a newer plastic joint. I thought it would be a good time to replace the joint and at the same time make them quick release!
Photo%2029-04-2015%2022%2030%2040_zpszo0
First I drilled out the old 8mm ball from the plastic throttle wheel. The ball is attached to a metal insert which is pressed into the plastic and this is easily cut away. A 5mm hole was drilled and an M5 ball pin screwed in by hand, which managed to cut it's own thread on the way in, very handy! To ensure it would last I bonded the part in with a Gorilla 2-part Epoxy Resin.
New ball size = 6.4mm
Photo%2001-05-2015%2017%2040%2057_zpsrdh
Next up is the ball on the brand new throttle body. Unfortunately there are no quick release joints to fit an 8mm ball, so this had to go. I was a little scared about hacking away at a brand new part if I'm honest but here goes nothing!
Photo%2001-05-2015%2017%2046%2049_zpsvkv
Ball whipped off with a dremel.
Photo%2001-05-2015%2018%2006%2056_zpsz1k
The centre was drilled out with a small HSS bit and the raised part then fell out of position, leaving a nice straight surface.
Photo%2001-05-2015%2021%2033%2057_zps6wh
This part was a bit of a nightmare! The remaining hole was too small for my M5 ball pin so naturally went to drill it out to suit, not so easy! I spent quite literally hours with various drill bits, including high quality bits meant for the job. I don't know what the hell this bracket was made of but drilling speed and oil cooling made no difference to the process. Got there in the end though and added a couple of washers and nyloc nut, fits very nicely.
Photo%2001-05-2015%2023%2033%2009_zpssnr
The quick release joints have sprung sleeves and have matching LH/RH threads to fit the original linkage rod. Added some thread lock to the rod and copper greased the joints.
Photo%2002-05-2015%2000%2022%2031_zpsfqt
All fitted and ready to go. I may need to short the rod slightly as the plastic wheel doesn't sit against the 'rest' when the butterfly is fully closed. I don't know if this is a real problem or not, other than adding extra load onto the ball pins?
Slo
Nice work and attention to detail :rolleyes:
lemmingzappa
Photo%2007-05-2015%2018%2038%2030_zpshir
Got the engine up on the crane ready to pull apart.
Photo%2010-05-2015%2015%2024%2008_zpsric
Off comes the pesky torque converter! Unfortunately my spanners weren't good enough to get the 3 bolts off with everything in place. I had to remove the sump first and then unbolt the first visible bolt, then turn the engine over and remove the other two as I went along. You will need another pair of hands to hold the crank bolt still with a breaker bar as you undo each bolt.
Photo%2010-05-2015%2015%2024%2003_zpsiib
Doesn't look too bad under there at a quick glance. Will most likely take some of it apart to inspect more closely at some point.
Photo%2011-05-2015%2017%2054%2017_zpsvr6
Photo%2011-05-2015%2018%2050%2055_zpsasa
Off comes the head!
Photo%2011-05-2015%2018%2050%2051_zpsusm
The head-gasket was a bit knackered, but not as bad as I originally thought. Time to take the head to the machiners!
Photo%2014-05-2015%2020%2055%2007_zpsflq
Got the head back today with 15 thou skimmed from the face, valves lapped, shimmed/clearance adjusted, new stem seals, new cam seal and DKZ cam fitted. I also got them to drill out a couple of bolts which had sheared off in the thermostat housing. There is some deeper pitting in a couple of areas of the face which I've been told shouldn't cause me any issues. Even with a MLS gasket.
Photo%2014-05-2015%2020%2055%2055_zpsaxb
Next I will need to fit the 'camshaft buffer' (part 081010) which will retain the DKZ cam in this head. Unfortunately as this is an earlier head I was unable to retain the cam using the first cap and require the buffer fork which sits right next to the cap at the pulley end. Will be making more progress with the engine this weekend.
idoari
are you planning to replace the auto gearbox with a manual one?
lemmingzappa
Yes, a 1.9 BE3 box.
lemmingzappa
Photo%2016-05-2015%2012%2018%2053_zpszzr
Replacing the water pump, tensioner & timing belt.
Photo%2016-05-2015%2013%2055%2057_zpsfxd
New pump on and looking fresh! I used new genuine bolts for the cam and tensioner at this stage, just to be sure.
Photo%2016-05-2015%2014%2021%2024_zpsdhg
GTi6 Multi Layered Steel gasket went on the block after cleaning the surfaces.
Photo%2016-05-2015%2016%2046%2059_zpspws
Head back on and torqued down with new bolts. The cam/crank pulleys and new timing belt were fitted, along with the new camshaft buffer acquired from Skip Brown.
Photo%2016-05-2015%2011%2039%2024_zpskge
Buffer as mentioned above, now the DKZ cam is happy :)
Photo%2021-05-2015%2019%2037%2041_zpsobn
I cleaned the sump out as well as I could with degreaser and brake cleaner. There's some really baked on stuff left in the metal imperfections.
Photo%2021-05-2015%2019%2037%2056_zpslaj
The turbo oil return pipe was leaking where it joins the block so I removed it to clean the surrounding area.
Photo%2021-05-2015%2019%2039%2025_zpsmpo
I re-sealed the pipe using loctite gasket sealant but it hasn't worked too well with the pipe sitting on its own. Once the turbo is bolted back on I will give it another go, at least then it will be held in place correctly.
Photo%2023-05-2015%2010%2009%2002_zpsf5l
The valve cover could do with some attention so I attacked it with wire brushes.
Photo%2023-05-2015%2010%2056%2022_zpsyn9
A bit better...
Photo%2023-05-2015%2014%2012%2006_zpszcw
Much better, silver VHT.
Photo%2023-05-2015%2011%2059%2030_zpssuf
Lightly cleaned and re-fitted the thermostat housing using Loctite gasket sealant.
Photo%2023-05-2015%2011%2059%2042_zps45p
New Valeo & Leader sensors fitted. I've fitted this according to the ServiceBox diagram, which shows nothing in the bottom right hole. I guess I will just keep this blocked with a bolt?
you don't need that brown one, its for the A-C, the other hole will be occupied by the green ecu temp sender which is shown on the ecu page not the thermostat page.
blue one you need to replace with the 205 sender, the 205 temp switch IIRC will fit where the brown one is, both same threads.
Edited by welshpug
lemmingzappa
Thanks for the info, I'm having trouble finding the ECU section on Citroen servicebox. I found the 'front harness' but doesn't have much info there.
EDIT: I searched for 'green' and managed to find it. Part number: 1920Q2
Edited by lemmingzappa
lemmingzappa
Also....
Just to confirm, '205 sender' is the dash temp gauge?
This: http://www.ebay.co.uk/itm/Febi-Coolant-Temperature-Sender-Sensor-Unit-OE-Quality-Replacement-Part-/390978371345?pt=LH_DefaultDomain_3&hash=item5b08207f11
'205 temp switch' is the dash warning light? If so, 105 or 110 degree?
lemmingzappa
Photo%2025-05-2015%2014%2017%2027_zpsgwl
Next it was time to clean up the block and give it some paint.
Photo%2027-05-2015%2017%2059%2055_zpsxxj
Much better :)
Photo%2027-05-2015%2018%2025%2057_zpst62
Photo%2027-05-2015%2018%2057%2013_zpsczq
New inlet gasket with a thin smear of sealant.
Photo%2027-05-2015%2019%2008%2018_zpssgr
New throttle body went on.
Photo%2030-05-2015%2011%2023%2052_zpsfsu
I removed the GTi loom from the car, ready to be grafted onto the XM loom for me.
Photo%2030-05-2015%2017%2059%2031_zpsu2t
Got myself a new turbo manifold seal, old vs new.
Photo%2030-05-2015%2018%2000%2035_zpszlc
Photo%2030-05-2015%2018%2007%2004_zpsl6i
Time to clean up the manifold a bit prior to painting with silver VHT again.
Photo%2007-06-2015%2014%2038%2049_zpsaf0
Much nicer! I also opted to use copper flashed nuts to aid with future removal. A couple of studs were also missing and I couldn't see sense in paying out for genuine items in this case. Opted for some stainless eBay specials and they appear to fit perfectly.
Photo%2007-06-2015%2014%2038%2039_zpsr10
New sensors in the thermostat housing.
Photo%2007-06-2015%2014%2039%2008_zpsxrh
Baby snail now in place.
Photo%2007-06-2015%2017%2023%2024%201_zp
Test fitting some pipework....probably won't be using the upper hose as I will be fitting a 406 SRi pipe at that end.
Photo%2016-06-2015%2018%2015%2041_zpsjhp
Pulled the fork off my 1.6 box ready to swap over to the 405 SRi/ BX GTi 8v box I got from Jackherer. At the same time the tin cover and diff needed re-sealing so whipped them off for a clean.
Photo%2016-06-2015%2018%2036%2004_zpseto
Photo%2016-06-2015%2018%2036%2020_zpsu45
Photo%2016-06-2015%2019%2035%2055_zpsp9u
Photo%2016-06-2015%2019%2015%2035_zpsnrk
I do unfortunately have an issue with the crown wheel attached to the diff. It appears to be an Mi16 part and won't mate up to the pinion correctly, causing the diff cover to foul. I will need to replace this with the correct 1.9 part which I am currently waiting for. If that doesn't fit either then the pinion will need swapping too, or opt for another box altogether.
Photo%2016-06-2015%2018%2016%2009_zpsk5m
Luckily I had this spring clip for the gearbox fork pin (which I believe is a 306 part), obtained from Paul_13 a few years ago and was a great piece of advice from him. Makes the job so much easier!
Photo%2018-06-2015%2013%2032%2034_zpsrgc
Next up I wanted to fit a GTi oil spray bar in the head as the plastic XM part didn't appear to have any spray holes at all and only fed oil to the journals. I've not seen this done before so not sure if it's truly required, but best to lube up the cam as much as possible right!?
I bought a set of genuine XM seals which are used on the plastic model and attempted to fit them to the GTi bar. Unfortunately once fitted the bar wouldn't fit into the caps correctly as they were too large, but without a seal it would come loose very easily (GTi appears to have smaller mounts).
Photo%2020-06-2015%2012%2041%2050_zpscbw
Instead I would recommend going for a smaller o-ring, such as the Viton type above. 4.5mm rather than 5 and also a smaller cross-section. They were a bit fiddly to get on and still wouldn't push into the caps easily, but a little persuasion with a rubber mallet helped massively and the thing is nice and secure now!
Photo%2020-06-2015%2012%2033%2008_zpshl9
Photo%2018-06-2015%2018%2034%2026_zps8me
Also fitted some new Viton seals to the injectors and bolted the rail up to the manifold.
Photo%2018-06-2015%2018%2034%2035_zpstre
Only issue here is I seem to have a small gap? I don't believe that is normal but I couldn't push them in any further. Will my rubber mallet have to come out again or is this acceptable?
Looking good!
I don't think the gap you are seeing on the injector is an issue in itself but do you have the plastic spacer/ring above the seal? The yellow ring on the left injector in this photo:
198858d1358350550-required-hardware-300h
lemmingzappa
Thanks mate. Yes I believe all 4 had the plastic ring attached. I will double check though!
