Supersport2
Mi16 89 Gti Resto
Supersport2
Yes, he's going to flatten it. Just painted over the weekend, still in the booth.
Slo
Sweet that wasnt meant to be a negative comment btw itll look lovely that red :wub:
Supersport2
Lol
aldworth33
Aye looks a good job, bet you can't wait to get it back together and drive it
dobboy
Looking good!
Putting it back together will be enjoyable, and if you have everything organised it doesnt take too long before it starts coming together.
Supersport2
Back from the painters!
CAB1E875-CE09-4F36-872E-CF264D21FE62_zps
0DE6E580-064C-4CB5-8FD6-584B9B895FEC_zps
Beam refresh!
6B702981-2661-4739-B22C-2E45804E0E61_zps
BA97A47C-D08E-4B6C-86FC-253FB6C2FAA0_zps
dobboy
If i were you i'd consider getting the car machine polished before you build it all up. (I regret not doing it with mine immediately after it came back from painters.) The painters flatten and polish it, but a good detailer would take it further and make your colour outstandingly shinny, and it would be reasonably quick/cheap as he wouldn't need to mask off everything. Or perhaps it's something you could do yourself.
you'll need to sort out some satin black for the door pillars too?
Supersport2
I've got the respray kit thanks, and engine stickers.
Never thought of a machine polish. Might give it a go! Thanks.
Supersport2
EE85210A-8E07-452E-ACD6-80AF15334B86_zps
Putting things back together slowly.
Still waiting for hubs to come back from the garage, with new bearings pressed in!
Supersport2
6555B7AF-70F3-4E54-96F0-E10808C52B49_zps
0C99F19A-B1B3-467D-A0A2-AACBA14FF110_zps
D2A9FA5E-7E14-4072-920D-6E127FAA8B36_zps
A112A0DE-A828-4347-A7CF-FE067B8EBABC_zps
Hubs are back! Wading through the loom, before we lob the engine back in.
Still having fun tho!
Loose Hand Luke
Looks great Mate!
Supersport2
954C056A-D695-4C6E-8B32-0C63AB1019BF_zps
Cheeky butt shot!!
aldworth33
That looks mint hope mine looks like that when I'm done
Supersport2
22F5BF93-3E56-47D6-A9F6-2E85D38DC2D5_zps
73DAB210-E57E-4387-9C2F-C680433C986F_zps
Reebmit
Looking good Justin, keep up the good work :) if you need any motivation check out my garage pics.... all red :)
Edited by Reebmit
Supersport2
Had a chew on getting the servo in, with the engine. Shame I painted it!!
650A5A45-A3BB-4670-9D03-82DD4103D757_zps
Can I remove these two plugs and associated wiring?
63CFB887-196A-4C06-BB63-8C6D529CB55E_zps
Cheers dude. Plodding on!! Lol!!
Supersport2
8E9D7A21-EC64-4596-B502-F6BF7BDF4538_zps
CE807DB9-2D66-4D1F-9022-2437476749EF_zps
AC818A0C-68D2-4674-9E53-D7B1E66F95E5_zps
D58EF376-F8B4-4E5C-BA10-CB13D8650C75_zps
AE6A915E-71F4-4764-982E-527FD4A597FE_zps
Supersport2
E4F4523D-5AE0-4C15-875F-C11DADCFB33C_zps
A little tight for the air filter. I've seen the smaller washer bottle and the spoox smaller inlet hose. Does anyone have any suggestions?
get a BBM inlet hose :)
You'll probably need a shorter filter too if you're planning on putting the washer bottle back in the standard position.
Supersport2
I've looked at the bbm website, but the discount code doesn't work.
It was a toss up between the inlet hose of a smaller washer bottle. Both are similar in price. If I had one or the other, I think I could get away with the filter.
Supersport2
Engine is now up and running!! Had a few issues, the fuel pump relay wasn't kicking in, but primed it by bridging the relay and went, once I put the leads on the right way!!
Majority of the lights are working, air horn is a struggle at the moment, hoping for someone to help with that!!! There's only two wires going to this relay, both carry 12v, and no other wires for the coil, inside the relay. So two wires missing, no idea where they've gone!!
Next is water plumbing and brake bleeding!!
