Jolly Green Monster
[Trackday_Prep] My Track Toy
alexcrosse
Tis short, makes sense when its just right.
How was everything else? Diff good?
Probably struggled to get temp into those rear tyres compared to the front, wouldnt have helped bias.
Jolly Green Monster
Minor fuel leak in return line just replaced with new from merlin as just there.
By the time I got it back to clutch cable needs adjusting and exhaust to manifold blowing but nothing a couple of hours wont sort.
Yes rear tyres were cold. Tried lower pressures but no luck. Might add a bias valve, hadnt considered tyre temp on the braking issue, good call.
Will sort gearing when I get chance
Jolly Green Monster
Diff was v good. Although a drying track was interesting wheel spin car went one way in wet and opposite in dry
alexcrosse
Those 048s are pretty good in the wet if you get some temp in, progressive.
Sounds like you had fun!
Jolly Green Monster
fronts have no tread left lol
well had allocated Friday to work on my race/drag car but then noticed track day at abingdon.. sorry drag car you can wait lol... 205 out again.
Simon
Jolly Green Monster
Removed a few more interior trims not needed, painted most of the floor and fitted new r888s to the front today. Loaded up and ready for trackday tomorrow at abingdon
F26BF7E5-D8AF-4328-B1E0-0B00E8790F9C_zps
Simon
HERMAN
Simon what size tyres are on the car? (looks wider than 195)
Jolly Green Monster
Only 195 with 309 wishbones.
Jolly Green Monster
Thanks.
Spent the day spanking it around abingdon, did 60litres of fuel and the new front tyres no need replacing oops. Excellent fun though.
calvinhorse
You need more camber
Jolly Green Monster
Agree it would help at abingdon but it has a lot of fast left handers where the front washes out. I doubt it would be as bad at another circuit. I do really like abingdon though.
Was faster than most on the bends, keeping laptime wise with a mates supercharged elise that 220hp, he was quicker on straights and slower on bends. Managed to embaress a lot of faster machinery.
alexcrosse
Looks good fun buddy.
Got adjustable top mounts on it?
Jolly Green Monster
no.. might look into sorting.. the current alignment was only done with string in a rush so will look at it again when I get time.
Couple more laps
Gman
Looking good mate. Nice tight line on that tricky left hander with the surface change mid way through. I always over cook it and turn in too soon and run wide. The tuition I had there was really useful.
Just fitted my LSD today, so hopefully that will tighten my lines up on a few corners.
Hopefully see you at Abingdon again soon
Jolly Green Monster
Thanks, I think I was stsrting to go too deep into a couple of bends and would have been slightly quicker turning in sooner but def feel the turn in cones are too early for a little 205.
Really enjoy Abingdon, a mates suggesting we do Woodbridge in may.
alexcrosse
Yeah you really need top mounts to pull the tops in then. I ran -2.5 or something. *runs away as a camber debate starts*.
Jolly Green Monster
Picking up castorkids gaz shocks friday. My cheap fun trackday toy is getting expensive. But still shadows the amount I have plumbed into the racecar so no bother lol
blandy
How did you find abingdon only trackday I've ever done
Jolly Green Monster
Very good. Lot of left handers to eats drivers front tyre but very open and lots of overtaking and the format is ideal for someone wanting to get into trackdays or test a car out.
Jolly Green Monster
Front Gaz coilovers fitted this morning, so easy to work on these cars.
Rear to do next, hope that plays ball lol
rallyeash
They are pretty mechanically simple which is great :-)
Coming on quickly, more power next?!
Jolly Green Monster
I do have a syvecs s6gp to go on it, just need to find the time to make the loom
