daneldridge23
Omex 600 In Mi16 Phase 1
daneldridge23
Hi guys where is the wire 112 tacho on a phase 1 and what switch live should i use?
Both wires are located by the wing mounted coil - switched live on the positive side, and one of the ones on the negative side is the tacho
daneldridge23
Hi mate i am trying to wire in the power to the ecu but im struggling! I have a feed from the battry, i have fuel pump wired in its earthed to the sterring collum, now just trying to loacted where the switched live is that i need and where to plug in the tacho wire on the omex loom
Like Anthony said, both of the wires you need to find for the coil switched live & tacho signal wire will be in the engine bay near the old coil mounting on the n/s inner wing.
You shouldn't need a seperate earth for the fuel pump imo, if you connect the Omex fuel pump feed to the wire that runs from the tachy relay it will work fine & still run via the original fuse.
g
Chris_Mi
Dan,
When you've got this sorted, could you knock up a "wiring for dummies" diagram?
:D
