N3VRAM
[misc_work] Introducing My 205 Rallye
N3VRAM
Be weary of them FirstLine track arms, they're dogs*it to put it straight. Lasted me no more than 3000 miles on the diesel.
Remind me on Friday about that rack and i'll get it sorted
oh really? if i'm totally honest i didn't think branding would make too much difference with something like those.. will defo keep an eye out <_< thanks paul
allye
take the window out your self, rub it all back and prepare it as much as you can. Let the professionals do the filler and spraying.
Paul_13
To give you an idea, I could spin the balljoint round freely with my fingers. The bushe had separated fully from the outer collar and banging on the large washer on the tie bar. On both sides pretty much
N3VRAM
oh dear, so if mine go the same way what brand did you go for after?
Paul_13
FAI/motorquip are pretty good. or swap over to Gti running gear. Handles much better in my opinion
Edited by Paul_13
allye
I'm not so sure Paul, I work on my car at a friends garage and the local, good quality motor factors is always delivering first line products. Maybe you got a very bad batch/item.
Paul_13
I've had quite a few FirstLine products that had failed super quick. Track rod ends, wishbones, strut bearings, bushes, rack ends. I steer clear now
cheesegrater
Those wish bones you had were dangerous mate.
cRaig
I had first line track tod ends that failed after less than 10 months, and looked worse than the onces they replaced! I have made a point of avoiding them totally in this rebuild.
Other than that, nice car and write up :)
S@m
Very nice 205! Even makes those saxo vtr wheels look good, which i thought was impossible! Mine has a touch of rust in that same place aswell, nice to see its easily sortable. Either way, liking the car and write up!
Sam
N3VRAM
Judging on what people have said im preparing for the worst with the first line control arms, see how it goes for now i suppose. I'm not a great deal fond of the VTR alloys myself either they will have to go one day but many more important things to do first!
Just typical that one of my rear wheel bearings has gone just before the weekend, and the monkey that got his hands on the one before has snapped the holes in the circlip.. been spending the afternoon so far trying to chizzle the circlip away to get the bearing out :unsure: .. also rear seatbelts need some adjustments to make the hole in the belt line up with the one in the boot so they won't be going on until mid-week (or if i can be bothered to get the file out tonight).
If you look at my original post you can see those horrible/cheap 8LED idicators, as one of them decided to drop off when washing my car this morning im considering just taking the repeaters out and replacing them with bungs, and then getting amber indicators, any thoughts?
Cheers for the comments and advice guys. Thanks, Matt.
N3VRAM
Chizzled out the circlip and then the bearing would come out no matter how many times i hit it with a mallet, in the end had to ask a neighbour to heat the thing up with his blowtorch and eventually it came out.
Quote some effort just to change a wheel bearing ^_^ new one went in easy as pie as the drum was still nice and toasty.
Edited by N3VRAM
N3VRAM
Thought i'd post a quick update here..
Not realy been doing much on the car recently, but i have been collecting bits! I also have three questions..
I had no bumpstops on the car, every time i went in a dip at any sort of speed i got a lovely scrape and figured these would help the problem a bit.. trouble was finding some bump stop holders! so my old man made me some:
So i fitted these and they helped a little bit - but i've since noticed that my car is leaning to one side at the back!? I'm going to try and change the shocks - 1. Is it atall possible for the torsion bar to soften (dropping one side)? Any advice on why this might have happened and what i could try to fix it would be great..
I've also bought these (to refurb):
As well as 3x106 rallye S1 steels.. 2. What is the difference because they look identical to me? 3. Also would you go for spraying or powdercoating?
I've also got a 4-1mani for a 106 which i hope to get altered and fitted asap.
Thanks for your help guys! ;)
Matt
allye
I'll let a beam expert answer that one.
S1 106 Rallye wheels are 5.5j and S2 are 6j, if I'd known how bad they scrub I would have got S1 wheels.
Podwer coating every time
Matt
N3VRAM
Thanks for your help Allye. How much was your rallye lowered by? as i've put the S2's on and they don't seem to scrape atall - even over the bumpy stuff! I've also noticed that since i've put these wheels on the back end no longer looks like its leaning, not quite sure what was going on...
On with a quick update - i went for a drive when we had the 'flash floods' to see if my rallye liked to swim... it didn't and i broke down after an hour or so and of course the floor filled with water. So out has come the carpet this weekend!
Also put some uprated engine mounts in the other day... things are not exactly 'relaxing' going up and down the a12 every day to say the least! :lol: Now i've gotta find some nice red gti carpet to get in.
I've since sorted the rust out on the floor (pretty bad in the drivers footwell) and gave it a really quick paint where possible. I plan to get some gromits to fill in any holes also!
N3VRAM
Okay so whilst my rallye's drying up inside for now i thought i'd try and sort the rear shocks out..
(for my own reference - BNE-1932)
Saw these for a good price on ebay so snatched them up, only done 6k on a stdt so hardly been ragged.
I fitted these yesturday and not noticed too much difference from the spax that were on the back but this has cured the car tilt problem i had (where the car sits lower on one side) which is good news! I know these are only supposed to be OEM replacements but they are a lot thicker and stiffer even than the spax that came off, i think it hasn't made much difference to the ride purley because of the angle they point at - theres never really that much travel compared to some cars that point much more vertical.
One thing thats really annoying me about this car is everything is so tightly cranked up (mainly by previous owners) and seized, im re'greasing everything as i go so this isn't as much of an issue in the future..
I'll update again soon.
Edited by N3VRAM
N3VRAM
Also remembered (on my way out to the car this morning) i replaced the chavvy side repeaters after one fell off for some gti ones. I'll probably change the actual indicators to orange rather than clear also.
erwin_meijer
Looking great mate B)
N3VRAM
Thanks Mate :)
I'm doing my first Gymkhana in the car tomorrow and im excited! Bought some Bilsten challenge spec struts for the front in place of the terrible worn out spax stuff that was there before, also put some EBC greenstuff pads on and fitted some goodridge hoses!
Hopefully i'll get some pics up after, off to have a cleanup!
MiniGibbo
Good progress dude, this has vertilly the exact same spec as mine just white lol...
got your struts on the wrong sides!
GeorgeXS
True, but doesn't matter seeing as he has base model suspension.
N3VRAM
Yes realised that after i got the first one in! :P But looking at the stuff that come off i saw it made no difference for my car like george says - and as long as they didn't scrape on the front wheel (which they don't) im happy!
Got back from my first gymkhana today, was great fun but unfortunatley i managed to run the tyre off the front rim round a hairpin on the last test!
TY Mate!
N3VRAM
Had my MOT and failed miserably...
One of the things which i was pulled up on was my track rod ends (which i was kind of aware about anyway). This evening i've taken an opportunity to put some new tre's on a spare rack Paul was kind enough to give to me (mine has quite a bit of play).. i seem to have a plastic gromet which i am unsure where to put on the rack, and was wondering if anyone could help identify before i take my old rack off the car?
Heres a picture:
Any help is much appreciated!
Thanks,
~ Matt
N3VRAM
Oh and just as Paul said, i failed on my tca balljoints after only 8months of having them installed.. will never buy anything branded firstline again - complete and utter s*it!
