Jake_GTI
Gearbox Oil
to drain my box, the drain plug is on the diff housing so would involve draining the diff aswell
The late Be1 & all Be3's drain through the diff housing, it uses the same oil as the rest of the gearbox & 2 litres is the correect amount for them both.
The picture I posted is a snapshot from the original haynes workshop / overhaul manual which isn't in the later style service & repair haynes.
Sarty's E reg Phase 1 had a box like this on it, was fine with 75W80 in there :)
Never said it wouldn't be fine just pre 88 Be1's are listed in Haynes as using engine oil. My 88 E reg got the proper Pug gearoil when I changed it but mine is a phase 1.5.
Graham.
woodsy
I had a similiar thing when i had a mates 1987 205gti in other month. It didnt have the usual filler on the end casing so ended up filling up through the speedo drive instead.
Early Be1'sjust didn't have a level/fill plug, i've had a couple, just top them up through the reverse lockout hole. 1.8 - 2litres will be fine from empty.
As Miles says, irrelevant of what Haynes or anything else says though, don't use engine oil, it'll eat the synchros!
Jake_GTI
yeah i drained it yesterday and topped it up with just 2 liters, ep75w/80 gearbox oil, took it for a small test drive and it all feels good so far :)
