By kirkas4,
07/25/2013
- 3,011 views
- Color Black
- Year 1988
- Short Description Quick
- Car Type / Usage Trackday car
ENGINE
Mi16 1927cc (stripped, tolerance checked, Chemically cleaned and rebuilt)
83.5mm IAPEL Forged Pistons
83.5mm IAPEL liners
Catcams Forged Conrods
Catcams Forged conrod bolts
Catcams 528 inlet/exhaust camshafts
Catcams Vernier Pulleys
Balanced crank, rods, pistons & flywheel
Spesso triple layer Kevlar head gasket
Mangoletsi inlet manifold
Longmans 4 branch exhaust manifold: Ceramic coated
Twin 45 Dellorto Carburetors
OMEX Ignition Management
Magnicor 8mm ignition leads
Lumenition Air / fuel ratio meter
Full Rolling Road Setup
XU10J4 26T oil pump sprocket and 52 link chain
DES Aluminium Direct Cold Air Feed to carbs
Samco water hoses
Baker BM Group N engine mounts
Heavy Duty Bottom Engine Mount
Powder Coated Rocker Cover
Lower Radiator Using Custom Aluminium Bracket
DES Aluminium Oil Catch Tank & Breather
DES Baffled Oil Sump
Steel Braided Fuel Hoses
Silkoline Pro R 15w-50 Engine Oil
Exhaust: Custom DES Stainless Steel system
Carbon Kevlar bonnet
TRANSMISSION
Re-built 1.6 GTI Gearbox
Quaife ATB Limited Slip Differential
Silkoline SYN5 75w-90 Gear oil
Quick-shift gear linkage
Mi16 Clutch
Lightened Flywheel
Quaife 2.4 turns Quick Rack
SUSPENSION
309 GTI Wishbones & Driveshafts
309 GTI front ARB
Gaz GGA Gold front Coilovers, 275lb springs, 2 degrees negative camber
Baker BM Eccentric Top Mounts
Sparco upper strut brace
21mm rear ARB
23mm Torsion Bars
Gaz GGA Gold Adjustable rear dampers
Group A Solid rear beam mounts
Skip Brown rear negative camber kit
Polyurethane suspension bushes
Brakes
BRAKES
306 GTI-6 Calipers
Standard vented discs
406 23.8mm master cylinder
Wilwood EXP 600+ Brake Fluid (High temp racing brake fluid)
Wilwood Brake bias valve with internal brake lines
Ferodo DS2500 Brake Pads (Front)
Ferodo DS3000 Brake Pads (Rear)
Steel braided hoses
Wheels & Tyres
Dry - Silverstone Semi Slicks
Medium - R888
Wets - R1R
- Bodywork & Exterior Standard
Interior & ICE
INTERIOR
Safety Devices six point roll cage
Stripped out interior, dash, heater, spare wiring
FIA Cut off switch
Lightweight Cobra Imola Seats
Lightweight 6 point Sabelt harnesses
Life Line fire extinguisher
Momo Steering wheel
Polycarbonate windows
Racetech Oil pressure gauge & Volt meter
Oil pressure warning light
Comments & Plans
Fiber Glass Boot
Light Weight Starter
Light Weight Alternator
Big Big Brakes
