lybker
Wanted: Diesel Wiring Schematics Rpm Gauge To Sensor
lybker
Please help me find wiring schematics for a 205/309 turbo diesel from instrument cluster to rpm sensor in enginebay.
Thank you in advance :-)
Richie-Van-GTi
is it covered by haynes?
http://www.buzzboxx.co.uk/Haynes_205.pdf
if not it should be same as a 306 td etc.
tdc sensor would be pin 3 earthed shield , pins 1 and 2 go to the tachometer, either way round should work but one way always works better than the other so fluctuating rpm should be cured from reversal. The tachometer will also have a power feed but from memory this is through the rest of the guages anyway so shouldnt be an issue.
Edited by Richie-Van-GTi
lybker
Thx for the reply - sadly there are no diesel models in the haynes book :-(
Your theory about pin-layout seems highly plausible - but still if any do have a wiring scheme - please share it with me - thx in advance!
Edited by lybker
Richie-Van-GTi
I took that direct from the 405 wiring schematics
lybker
nice - do you by any change know what is the sparepart number for the sensor?
jimistdt
I bought the Haynes "Peugeot/Talbot Diesel Engine #950" from an ONLINE store. I only paid about £7 for a used one :lol:
lybker
u shouldn´t by any chance have a scanner - do you? ;-)
jimistdt
No, mate unfortunately not. Plus I cant read them well enough to tell you what you need to know.
Maybe Welshpug on here can get access to one.
I will say though, when I ordered mine I had it within 2 days, and they are worth having.
