timmsy19 3 Posted January 1, 2009 hi all. First off iknow this has nothing to do with a 205 so if this is in the wrong section please move. Right well my mum has been having issues with the heater blower on her car, ive checked power from the ignition and its working perfectly. now ive also checked the connection under the glovebox but the power dosnt seem to be getting that far. Anyone have any ideas where i should be looking? Share this post Link to post Share on other sites
welshpug 1,737 Posted January 1, 2009 there's no relay, fed from F20, via a speed control unit, a resistor unit, and the Motor, at least that's what the Haynes manual says Share this post Link to post Share on other sites
Miles 331 1 Cars Posted January 1, 2009 There;s a relay for this on the 306, Not quite the same car I know but close enough, Just pull the relays out of the fuse box and check them for sign's of heat Share this post Link to post Share on other sites
jackherer 543 Posted January 2, 2009 Its usually the slider control that dies on Xantias, I've changed loads over the years. There are two different parts, ac and non-ac so make sure you get the right one if it is this. Share this post Link to post Share on other sites
