Guest paky Posted December 12, 2008 (edited) Temperature guage on my ph1 s16 shows 105C and than thermostat opens. I can fell when radiator gets worm. When i ride temperature is about 105-110C on guage.Afeter 110C fans comes up at low speed. Iw tryed to change thermostat and same thing, iw tryed to change temperature sender and same thing again. I dont think that engine is so hot under hand.Looks like problem is in temperature guage, what do you think. Maybe bad grounding. Please help Edited December 12, 2008 by paky Share this post Link to post Share on other sites
pug_ham 241 3 Cars Posted December 12, 2008 It could be that the senders are wrong but has your instrument panel ever been taken apart for any reason? (white backs or something) If they have been apart then its a possibility that the needles aren't in the right place. Where do they sit when the ignition is switched off? Graham. Share this post Link to post Share on other sites
Guest paky Posted December 12, 2008 nope, temp. guege was working untill last few days Share this post Link to post Share on other sites
