hcmini1989 16 Posted December 4, 2008 right im about to start to make a manifold to take my r carbs on my mi16 engine just hit a snag though the old mi manifold has three takeoffs on it i think one goes to the servo not sure about the other 2 do i hve to put these on the new mnifold if so how becaude wont it suck in fuel aswell s ir in the vcum or is there anyother way round it like myb a vacum pump ive had a look round nd cant seem to see ny take offs on any body elses Share this post Link to post Share on other sites
mattbenselin 0 Posted December 4, 2008 You will just need 1 take off for the brake servo I think. Don't transfer the others. Sure other people will be able to back me up but I'm pretty sure. Share this post Link to post Share on other sites
ORB 227 1 Cars Posted December 4, 2008 what matt said is correct. Share this post Link to post Share on other sites
DrSarty 100 1 Cars Posted December 4, 2008 (edited) You will just need 1 take off for the brake servo I think. Don't transfer the others. Sure other people will be able to back me up but I'm pretty sure. Yep, just one for the brake servo, and, if you need it with carbs (I don't know carbs) one for the FPR. Ooh and P.S. no texty typy please. We no likey! Edited December 4, 2008 by DrSarty Share this post Link to post Share on other sites
hcmini1989 16 Posted December 4, 2008 so should i just put a take off on one of the tubes [there will be 4 tubes going to the carbs] but woulnt there be fuel in the vacuam pipe and brake servo then as the normal mi manifold only has air in it Share this post Link to post Share on other sites
Peetypug 5 Posted December 5, 2008 just put one take off on one of the pipes. I had one made by bogg brothers, it only had the one for the servo It had nothing in it to stop fuel so i dont think there will be an issue with it. Share this post Link to post Share on other sites
pip470 63 Posted December 5, 2008 (edited) The engine is sucking so no fuel will go up the pipe. Its a vacuum pipe to the servo. I think your just thinking about it the wrong way. I can see how you have come to that assumption though. If you do not understand what I mean, let me know and ill try another way. Hopefully you will get it from this. Phill Edited December 5, 2008 by pip470 Share this post Link to post Share on other sites
unariciflocos 49 1 Cars Posted December 7, 2008 I'm halfway through making my bike carb manifold but i'm going to get vacuum from all cylinders into a copper 35mm diameter pipe that will act as an accumulator. From there i'll go to the brake and advance for the dizzy. I heard this is the best way to do it. Am I wrong? If so please explain. Cheers, Andrei Share this post Link to post Share on other sites
mattbenselin 0 Posted December 7, 2008 Your not wrong, but your making it a lot harder for youself. The vacuum tubes serve just to create a vacuum inside them which means you are not going to draw anything through them or spit anything up them so the cylinders won't be unbalanced. Everyone else (Bogg Bros, Shenpar, Weber, etc) use one take off and they make proven products. 1 will be adequate. Share this post Link to post Share on other sites
unariciflocos 49 1 Cars Posted December 8, 2008 I'm still going to go for all fours and an accumulator, get the ripple out of the vacuum and balance it between the cylinders. I want to do this because I'm guessing my Kent PT23 cam (304 duration) will mess with the pressures even more. Share this post Link to post Share on other sites
