Rupes 0 Posted December 4, 2008 I've had a good search but I can't find anyone having asked this before, probably because it's a stupid question, but anyway, here goes. I'm trying to reconnect the bonnet release cable on my Rallye (long story involving a wet road, blind corner, queue of stationary traffic and a bush), there's a bracket about 18inches back from the end, where the hell does it bolt on - it's the last thing to do on my repair? Having said all that, how should it route through the engine bay - it's just poking out from the bulk head at the moment and is no good to anyone? Share this post Link to post Share on other sites
DrSarty 90 1 Cars Posted December 4, 2008 (edited) it's a long story involving ... a bush It comes (as you face the car/engine bay), along the inner right wing, curving round to a usually rusted on metal clip under the metal bit over the right hand headlight, where it continues on to the underside of the slam panel and the latch mechanism. It is possible that the clip, which grips the end of the cable outer fastens to the underside of the slam panel, but it's in that area. HTH. Edited December 4, 2008 by DrSarty Share this post Link to post Share on other sites
GLPoomobile 958 Posted December 4, 2008 From the bulkhead it goes (IIRC) along the inner chassis leg behind the battery, and then either over or under the washer reservoir, then in the front corner it twists 90 degress to come back along under the slam panel. The bracket you refer to I believe is only a little thing, which fastens under the headlight panel I think. Should be a single screw that goes down through one of the holes in the headlight panel. Share this post Link to post Share on other sites
welshpug 1,622 Posted December 4, 2008 Not much detail here, but a shows all the parts. Share this post Link to post Share on other sites
Rom 0 Posted December 4, 2008 The route isnt viatally important, i had to move mine around a bit. And as said, the little 'p' type clip does indeed bolt onto the NS headlight panel. Just along from the big circular hole, there are some more smaller holes. Its one of those, whichever gives best cable slack etc is fine. Share this post Link to post Share on other sites
Rupes 0 Posted December 5, 2008 Brilliant. I stuck an M6 bolt through the big hole in the panel above the nearside light, bolted the P connector to it and, after some lock re-alignment it worked. Thanks everyone for the help. Share this post Link to post Share on other sites
