lfallgti
Starting Trouble
lfallgti
hi all,
almost completed a 1.6- 1.9 conversion and i'm having problems getting it to start. all pipes and connections seem to be in the right places but it seems to one minute have a spark and fuel, then the next i'll have nothing. i have managed to get it to fire but it doesnt want to do it consistently. i have replaced plugs, leads, dizzy cap and rotor arm and have also got an extra ignition amp and coil. i am assuming that if i have a spark the injectors should be firing? all ancilleries apart from the starter motor and alt are the 1.9 items. any help is greatly appreciated.
steve@cornwall
hi all,
I'd start with checking the lead between dizzy and amp - check the connection and that the connectors in the plug haven't pushed straight out the back of the plug. Also, the ph1 1.5 clip-on cap dizzys have a habit of fraying the wiring where it leaves the dizzy and shorting out
lfallgti
would that be the yellow plug from the dizzy to the black connector?, if thats right it would make sense as when i put a spark plug in the king lead it sometimes sparks when cranking then sometimes wont.
i'm wondering now if i may be moving the dizzy lead just enough when pulling the king lead from the dizzy cap to make a good connection (or bad).
thinking about it, (i'm not near the car now) the yellow plug does look as if it isnt connected fully, i will have to try tomorrow and see whats what. sorry if that all sound confusing
thanks
lfallgti
it was indeed the dizzy lead, will be fixing it tomorrow, have a spare dizzy and lead so should be good to go tomorrow
thanks
