Moz_Goodwood
Turbo Headgasket
Moz_Goodwood
what sort of power can a standard XU10 J2TE engine headgasket take? are they a pretty good design as standard or should i uprate it? if yes any recommendations?
seeing as the engines out im going to replace the one ive got anyway
cheers all
paul
Moz_Goodwood
anything else to consider checking when the engines out?
my list at the moment is headgasket, cambelt, aux belt, water pump, tensioner and exhaust gasket.
anything else?
matty_gti
Just get a HG from Peugeot and you'll be fine.
The above sounds fine....just missing headbolts :) . I would also get the water pump from Peugeot as ive seen copied ones fail within a few hundred miles, I had a tiny leak from mine.
Matt
Edited by matty_gti
I'd get a GTi6 Gasket, MLS as std, The turbo one just has very minor upgrading to the ring's around the bores, not sure what they take as I used this on the one I did with 240Lb Ft of torque
