bensonmi
Mi16 Not Starting
bensonmi
righteo!
ignore pin 15, i made a mistake! :)
earths are pin 5, 16 and 19.
pemanant is pin 18.
switched lives are pins 14, 19 and 21.
taken from my 2 row ecu chap.
mike
cheers il give that a try tomorow, will it make any difference that its a 3 row in mine?
darojac
On a 3-row ECU, the permanent live is on pin 18, wire 1B, and the switched live is on pin 27, wire 2E. This also goes to the coil, pin 3, wire 2A, and to the Ignition Amp pin 4, wire 2B.
When cranking, the injection relay coil pin 2, wire 36, is earthed via ECU pin 36 - it has a permanant +ve on the other side of the relay coil at pin 1, wire 1B, and therefore energises. This in turn puts a +ve onto the fuel pump relay coil at pin 1 wire 20B (as well as to the injectors, the ICV and ecu pin 37). The other side of the relay coil at pin 2, wire 20C, is earthed via the ecu at pin 3
Hope this helps
Dave
bensonmi
Hope this helps
Dave
ok, here is what iv found today
pin 18 / 27 / 3 / 4 / 36 / 1
volt 9.77 / 11.91 /0.14 / 0.14 / 9.55 / 1.84
does this make any sense? its all with ignition switched on,is there any thing else i should check?
cheers again for all the help! :D
Edited by bensonmi
Mikey S
pin 18 voltage is low, should be battery voltage. its lost 3 odd volts somewhere so you may have a poor connection/bad wire somewhere.
pin 27 is ok.
pins 3 and 4 should see battery voltage. indicates a bust wire somewhere.
pins 36 and 1 will need to be checked when engine is cranking.
does it still crank benson?
mike
bensonmi
pin 27 is ok.
mike
yeah it still turns over fast but no sign of firing!
Mikey S
i really think you need to start having a dig through the loom with a meter and check the wiring out. it sounds like theres a broken/damaged wire somewhere.
bensonmi
ah sounds like my worst nightmare!! looks like i got some more fun times ahead of me!but hopefully il check the 1s that are down on power and i could be lucky,doubt it tho,im not that lucky :D
philfingers
ever get this sorted out, if so what was it?
bensonmi
no still the same,thinking its the alarm/immobiliser playing up so waiting for my friend to take it and remove it all. but hopeing to give it another try tommorow once the shafts are back in.
