MrG
Oil From Driveshaft/diff
MrG
Maybe a stupid question but I don't know the answer.
Anyhow I changed the front struts on my car and accidentally pulled the driveshaft too far (don't ask but all sorted now) anyhow lost some oil and not sure if its engine or gearbox? (My old mini shared the same oil hence the question) if Gearbox where do I refill as I couldn't see during my cursory glance under the bonnet.
Many thanks
jimistdt
Easiest way to fill the gearbox is thru the left wheel arch, turn the steering lock right and you will see a nut about halfway up the 'box housing, fill up in there till it comes out.
See if this thread makes it any easier for you CLICKY
Edited by jimistdt
MrG
perfect thanks Jim, I did a search but the topics are not always clear from the titles.
