malyso 0 Posted November 3, 2008 (edited) Has anyone who's done this conversion and used the alloy spacer block for the dizzy found that the bolt holes for the dizzy body are not in the right place when the car is running sweet. I'm wondering if i need to alter the cam timing(either vernier pulleys or move round one tooth) to get the body in the right place to bolt it up? This one is mine.. This one i found on ebay with different bolt hole positions? Edited November 3, 2008 by malyso Share this post Link to post Share on other sites
Edp 67 3 Cars Posted November 3, 2008 Not being rude but why not rip all the old 8v tosh out and put the 16v wiring in? use the proper management with the 16v engine Share this post Link to post Share on other sites
welshpug 1,715 Posted November 3, 2008 Not being rude but why not rip all the old 8v tosh out and put the 16v wiring in? use the proper management with the 16v engine Ditto!! they run so much nicer on it. and if its on carbs, yuk! fit Omex Share this post Link to post Share on other sites
matty_gti 20 Posted November 3, 2008 Not being rude but why not rip all the old 8v tosh out and put the 16v wiring in? use the proper management with the 16v engine Nothin wrong with 8v's Share this post Link to post Share on other sites
Miles 331 1 Cars Posted November 3, 2008 All the Dizzy adaptor's are different and I've yet to find one which has the holes in the correct position, I just position the Dizzy pretty much as std (on a 8v) and re-drill and tap some normal size holes, Not M7 Share this post Link to post Share on other sites
malyso 0 Posted November 3, 2008 Thanks will be re-drilling and tapping. Share this post Link to post Share on other sites
malyso 0 Posted November 3, 2008 Ditto!! they run so much nicer on it. and if its on carbs, yuk! fit Omex I was hoping it would pull much better at the bottom end on carbs, it was already wired up with proper MI16 loom and management... Share this post Link to post Share on other sites
hexhamstu 9 Posted November 4, 2008 so whats the craic with running a mi16 on carbs, on mi16 management??? Share this post Link to post Share on other sites
