decoc182
Xsara Vts Enigne Into 205
decoc182
Hello people i've seen a xsara VTS for sale and was considering puttin the engine into my 205 xr 1400 shell. i aint seen it been done on the xr shell yet only on gti shells. also would the xsara rear beam fit onto the 205?? Cheers for your help fellow pugsters...
Rear beam won't fit straight on no.
Do a search regarding the XU10J4RS conversion into 205's though, plenty of info.
SurGie
The rear arms will fit the beam and has 1.2 neg camber with 0.5 toe in, as i recall, you will need
to use up rated ARB/TB's.
A good road set up but not as good for the track.
:lol:
Ignore him... you don't have to do anything.
& the Xsara VTS trailing arms have 5mm toe-in, and 1'20m of camber. :)
SurGie
Yeh sorry, i ment to put 5mm toe in not 0.5, and 1.2 / 1.20mm.
But the xsara arms will fit the 205 beam fine if you wanted that sort of upgrade, there
is alot of posts on here about the differance in arms and their +'s & -'s for road and track use.
The beam like baz said wont fit in.
The car will feel more planted to the road with the xsara arms, yet not as good for track with
the toe in on them.
