Chaff
Central Locking
Chaff
Should the boot be on the central locking system?
Just brought a gti 3 door and the doors lock and unlock but i have to use the key for the boot.
Is this someting that needs fixing or just how it is?
Regards Matt
should be
could be a number of things, seized mechanism, seized motor, broken wire, bad earth etc.
Chaff
Are there any tricks of the trade to pump a little live back in it?
SurGie
[/quote
test the wire for a live then if it ok, get a new central locking motor.
Chaff
Good thinking, will do. Does it not have a earth then?
Edited by Chaff
SurGie
Hi,
If you use the live wire screwdriver tester it has a wire from it for the earth, u then attatch it to a
good solid metal area to earth it then use the screwdriver bit where the live wire is and if the tester lights
up then there is power going to the motor.
Im not sure which is the live wire though of hand and i think you have to
switch the central locking on and off to see if there is power there.
Hope it helps, i bet the motor has gone to be honest.
