djinuk
Heaters Stopped Working
djinuk
My heaters in my 205 gti have stopped working.. the fan just wont do anything.. anybody have any suggestions. any wires to check on the fuse box etc?
Atari Boy
There is heater motor resistor under the glove box, this oftern stops working.
GSF do them here.
GSF on eBay
Or pick one from a scrappy, which is what I will be doing.
HERMAN
If it has blown the resistor or the fuse then check that the motor is turning freely because usualy if the resistor or the fuse blow it is becasue the motor is starting to seize up and draw more current(power).
Always check the fuse first then the resistor. Also check to see if you are getting power to the motor and resistor because it could be the control switch. I belive that the control switch controls the negative and not the positive unlike most other car's.
Edited by HERMAN
djinuk
fuse appears to be ok, how do i get to this resistor ?
Atari Boy
I picked one up from a scappy for £3 today.
This may help, my thread
djinuk
yep found it, ill whip one of my other pug to see if thats the problem. thanks
HERMAN
If you have any trouble let me know I see you are in the Derby area and could pop round and help you.
Neil
djinuk
cheers for the heads up man.. ive found the problem, its not the resistor , the spin switch thingy has fell to bits, how do i get at it to remove it ?
