yorkshirekowboy
The Inner Bearing Measurment.
yorkshirekowboy
silly of me but i didnt measure the distance from the out lip of tube to the bearing, but on the guide it says 20cm, is that excluding the rubber outer seal or with seal, as i have not got the seal on yet, so am i to measure 20cm from the outer bare lip of the tube 20cm to the start of inner bearing?
t
that's before you fit the seal :unsure:
yorkshirekowboy
thanks for the prompt reply as ever, wil start that tomoz, needing some new shafts, just had a quote on how much they cost. wow
try GSF, not sure if they can still supply them.
yorkshirekowboy
are they proper genuine pug ones?
they were when I bought a pair not so long ago @£39 each, even came in Peugeot boxes.
yorkshirekowboy
juts been on gsf website,
is this the part?
T42604 REAR ARM 205 REAR X MEMBER INNER TUBE 43.50????????
is this the part?
Yes but I've heard they have stopped selling them again.
Graham.
yorkshirekowboy
that's before you fit the seal :D
i will ring tomoz, so juts to clarify, its 20cm from the outer edge of the beam tube to the inner bearing.?????
They have stopped selling them, or they had a couple of weeks ago anyway.
