Guest martin01743 Posted October 23, 2008 (edited) After fitting my M16 with BE3 into 205 which used to have BE1 i now have a gear stick that you need ten foot arms to change gear with and exaust clearance isues. Does anyone know if the gear levers on 205 14XS are diferent in anyway to 16/19GTI? Edited October 23, 2008 by martin01743 Share this post Link to post Share on other sites
welshpug 1,624 Posted October 23, 2008 did you swap the selector arm from the original box? Share this post Link to post Share on other sites
Guest martin01743 Posted October 23, 2008 No couldnt get it off so using the original 405 one at the moment Share this post Link to post Share on other sites
welshpug 1,624 Posted October 24, 2008 that'll be the problem then, just knock the roll pins out of the shaft and swap the arms over, take care not to let the shaft drop into the box. (there's 2 roll pins, one smaller inside the other) Share this post Link to post Share on other sites
Guest martin01743 Posted October 24, 2008 I will give it a go, but think it will be hard work as not alot of room, Thanks for advice. Share this post Link to post Share on other sites
