SPGTi
Oil Cooler
SPGTi
At the moment on my 1.9 8v I don't run an oil cooler but when I change to 16v I think this may be necessary.
The car is used for road rallies, so is kept at high rpm in 1st, 2nd and 3rd for fairly long periods of time.
So my questions are :
What size cooler : 235mm 13 row ?
Keep the std take of plate and just make up new hoses or is it worth getting a new take off plate with in built stat and maybe even take offs for oil temp and pressure gauges ?
Is the std place to mount the oil cooler the best ?
Where is the best (cheapest) place to get the kit ?
cheers
Steve
13row seems to be the common application, i have one with the Mocal take off plate and braided hoses etc, but i see no reason why you couldn't use the std kit.
http://i49.photobucket.com/albums/f255/205.../DSC00005-1.jpg
Happy birthday btw Steve!! B)
Edited by cybernck
Stu
I run this setup too, 13 row Mocal with take-off (no stat) and the hoses were made to my spec by pirtek..
And to feed it with cold air...
SPGTi
Thanks !
I am wondering whether I will need a stat or not. Some events in winter are pretty cold and when lots of water is involved the oil gets cooled pretty quickly, so I don't want to also be cooling it with a big cooler.
Stu,
That looks a neat installation I would just be worried about breaking it being mounted that low.
Does anyone run these take off plates that also have threads for oil pressure / temperature gauges ? It would just seem to be handier than having to tee off the standard switches.
Steve
Atari Boy
Nice, any pics of the bumper fitted on the car?
tom_m
my 13 row lived here briefly and came to no harm, with a stat take-off and the hoses that came with it.
Edited by tom_m
I would, I did a trackday at the weekend with a freshly fitted mocal and stat a couple of days ago, using an SPA digi temp gauge it didn't reach 80 degrees (the stat opening temp) for several laps so the stat was closed for that time. After that the temp fluctuated between 86 and 88 presumably as the stat opened and closed. On the road its not going to open apart from sustained high speeds I wouldn't have thought.
Very pleased with how it worked overall, last time we took this car on track it could only do 7 or 8 laps before the oil was burning hot and now it can go indefinitely on the same track. This is on an S16 with a tin sump that had no oil cooler at all before.
Stu
Only these mate...
Atari Boy
Only these mate...
Nice work, it looks good. :unsure:
