Jakob
Xu7jp4 Crank In Xu10 Block
Jakob
Some theory: Having the inlet valve area from a XU10 top and a 1.8 crank in a XU block should/may give almost same tourge as with standard 86mm crank, as in theory it will peak further up the rpm line and thereby giving more hp.
Therefore adding a XU7JP4 crank in a XU10 block could be interesting in some situations... ;)
(XU block would be with oil spray bars under pistons e.g. XU10J4R, J2TE, RS etc).
Pistons and rods figures (XU7JP vs. XU10xx)
XU7JP: (BFZ, LFW, L6A, LFY, LFZ, L6B)
- Length: 150.5mm
- 48,655 mm
- 22 mm
XU10J2: (RFU, RGX, R6D)
- Length: 152 mm
- 53,695
- 22
XU10J4 (RFT, RFY)
- Length: 152 mm
- 53,695
- 23,003
XU10J4RS: (RFV, R6E, RFS)
- Length: 158.00 mm
- 53,695
- 22
The rod bearing diameter is different from XU10 versions, but using the XU7JP rod should fit a XU10J2 piston (22mm)
Questions:
1) Have anyone fitted a XU7JP4 crank in a XU10 block?
2) Would the crank fit?
3) What are the crank diameter (81mm?)
4) Anyone got pictures of the crank and rods? - the crank should be full counterweighted
I am looking for a CR 9:1 with a XU10J2 head and havent done the math yet (missing crank diameter and dish from XU10J2 head and pistons)
Maybe some standard components could be used (any experience?) else custom pistons/rods.
/Jakob
Edited by Jakob
Sandy
XU7 is 81.4mm stroke. It's do-able, but you'll need custom rods. The XU7 big end is 45mm
Jakob
Thanks. What do you mean by 45mm big end?
I have found 22mm and 48,655
Sandy
48.655 is the bore in the rod, with the bearing fitted it's 45mm.
Jakob
Thanks! - anyone else with experience on this swap???
Jakob
Anyone with experience??
Would the crank fit straight in??
guffe
It should. XU10 crank didn't fit straight into alloy block (would have needed some grinding) but vice versa should fit just fine. I can't be sure because I just sold my XU7 crank.
