TRYNKEEPUP
Steering Dosent Feel Right
TRYNKEEPUP
Hi i seem to have a bit of a problem with my 1.9 gti, non PAS, or ABS. the steering feels vague, steering wheel not centred, seems to wonder a bit, if i hit a bump in the road sometimes the wheel sits straight, it just dosent feel nice and tight like it should, i have recently replaced everything on front end, bottom arms, with poly bushes, track rod ends, brakes, suspension, and all new nuts and bolts, i have jacked car up today and checked everything all seems fine no play in anything, has any one esle had this problem ! was wondering if the steering rack is on its way out ? any ideas.
pete1986
Mine has very similar symptoms, and have found its the rack. There's play in one of the ball joints. Get a mate to turn the steering wheel from side to side a little whilst you feel for play there
hengti
also, disconnect the lower column U/J from the rack and check that it's not at all stiff
Flix
Have you had your tracking checked?
Always check for play in the suspension and steering before getting the tracking checked as play can make the alignment appear to be wrong and correcting it will just make it worse.
TRYNKEEPUP
I did check ball joints on car while steering was moved side to side, bottom arms are only a couple of months old, also did have tracking done at a garage and has been spot on till this problem arose
