Tommer
What Are These For? Anyone Know
Tommer
hi guys,
keep finding things with nothing attached and wondering if anyone here can help put my mind at rest:
should this plug into anythig? it has a green and a brown wire inside the black sheath, but the green has snapped...
is the the TDC sensor connector?
is this for diagnostics?
is this one for diagnostics?
is this normal? can it be removed?
this one seems to be something some previous owner has done, maybe for an amp?
Also is this the Air fuel mixture adjustment:
Air Flow/fuel mixture adjustment?
Thanks heaps in advance guys
tommer
hi guys,
1. should this plug into anythig? it has a green and a brown wire inside the black sheath, but the green has snapped...
2. is the the TDC sensor connector?
3. is this for diagnostics?
4. is this normal? can it be removed?
5. Air Flow/fuel mixture adjustment?
tommer
1. No, pretty sure that does nothing.
2. No, it's the fan test plug
3. Not sure, but it's never plugged in.
4. No not normal, can be removed if it doesn't do anything!
5. Yes
Edited by Baz
