jtek 0 Posted September 20, 2008 At the moment I have the 266 discs and calipers from a 306 HDI. I chose these because they are apparently a fair bit lighter then the GTI6 items, but then again at the time i wasn't planning on going down that route engine wise. Does anybody this setup on a GTI6 powered car? whether it be with uprated pads and fluid etc. Also, I currently run Gaz adjustables up front (non-coilover), and with the heavier mass i feel its probably wise to go with the coilovers, especially as there is a group buy running at the moment, and i was just wondering what sort of spring rates and lengths people are running for track use? Cheers Share this post Link to post Share on other sites
Anthony 1,000 Posted September 20, 2008 266mm brakes will be plenty upto the job of stopping a 205 GTi-6 - just stick some reasonable pads in them and some fresh fluid, and they'll take all the abuse you can throw at them on road and track Share this post Link to post Share on other sites
springs 0 Posted September 20, 2008 im guessing the 306 brakes are a straight swap on the 205's ? Share this post Link to post Share on other sites
James_R 3 Posted September 22, 2008 (edited) I'm still going with std 1.9 brakes on mine DS2500 pads, wilwood bias vlave (rear comps pulled out) and 5.1DOT AP fluid not had any issues when I was running an Mi. Might try EBC yellows next though. Oh and 1.6 hubs won't take any other brakes bar 1.9 calipers still on 1.6 discs (but even this is enough of an upgrade) Edited September 22, 2008 by James_R Share this post Link to post Share on other sites
Alastairh 47 Posted September 22, 2008 S16 calipers is a nice little upgrade. Cheap as chips from the scrappy, reasoanble selection of pads available. Also means you can still chuck 14's on aswell. I've also done this conversion to a iron blocked 16v 205 and done the job fine. Share this post Link to post Share on other sites
jtek 0 Posted September 22, 2008 Cool, I was probably going to look at some better fluid and DS2500's anyway. Any idea on front spring rates? I am not too fussed on ride comfort but obvious its got to be driveable on the road and not dancing around the place. Cheers Share this post Link to post Share on other sites
