Ryan
Removing Rear Quarter Badges
Ryan
Is there a trick to getting these off easily, or do you need to take the interior trim off and push them from the inside?
jimistdt
I depends how they've been made to stay there, mine have been liberally applied with Mastic and they wont come off easily, If you do break the lugs you can always resort to that too.
Jimi ;)
Veero
No need to remove any trim, just pop the rear speaker grills out and you should just be able to get to the inside to push the lugs out.
Be careful though, you only need to push the very centre pin out as there is a three prong plastic clip thing that the quarter badge clips into.
Use something with a small but not pointed metal tip, like a ground down compass point or something.
