Tommer 0 Posted September 17, 2008 Hi all, had to replace the rear flexi hoses as part of the MOT, however getting them un-bolted from the solid ones on the rear beam now means i need new solid ones as well grr! can anyone suggest somewhere that sells them, Peugeot want 12.61+vat each side just for the rear solid ones, plus there is long wait as they have to order them in! any help appreciated, or if anyone can suggest a cheaper upgrade / cost effective upgrade or part replacement that would be cool. thanks in advance, tommer Share this post Link to post Share on other sites
BusEngineer 7 Posted September 17, 2008 I went to alocal place we use for pipes for the buses called L&H, £8 per pipe made up, id try more places than just Peugeot mate Share this post Link to post Share on other sites
cazzy93 0 Posted September 17, 2008 You could just buy some copper brake line a couple of different ends depending on what you need and a flaring tool and make them up yourself and then you have brake pipe and the tools to make pipes up in the future. Share this post Link to post Share on other sites
Anthony 1,000 Posted September 17, 2008 Most garages should be able to make you new solid lines while you wait if you bring in the old one as a template - both unions are M10x1 If you get really stuck, give me a shout as I've all the kit to make new solid lines and I'm 30 minutes from Bristol Share this post Link to post Share on other sites
