wardy18
306 Xsi 1800 16v Gearbox
wardy18
What Ratios and CWP etc are in the 306 XSi 1.8 16v Box?
Its not on that Ratios spreadsheet......?!
Thanx
alync406
There are alot of different ratios for these gearboxes.I looked on servicebox and the Final drive ratios can be - 4.53,4.4,3.79 or 3.95. First gear seems to be the same for all - 3.45. Second - 1.87,1.74 or 1.95. Third - 1.28,1.36 or 1.15. Fourth - 1.05,0.95 or 0.82. Fifth - 0.79,0.86,0.65 or 0.74.
I wanted different gear ratios for my rally car and i did not find any of these gearboxes with a 4.53 or 4.4 final drive.I got a final drive out of a Berlingo which was a 4.53,but the problem with this was it was a BE4 gearbox so 3rd and 4th out of the 205 gearbox wouldn't fit this shaft as the splines were different.I sorted this by getting a BE4 out of a 1.8 406.The 3rd out of this was 1.36 and fourth 1.05 which is the same as the standard 205 gears and i also used the fifth out of this gearbox which was 0.79.I am really happy with this gearing it has made a big difference to the car.
wardy18
Ah ok is there any markings on the box to show what it may be? Its jus i have one available to me with an engine im buying but dont know if its any use to me an i could get the engine cheaper an reduce courier costs if i knew the box wasn't any good to me so only took the engine!
alync406
The only way you will know what final drive ratio it has is by taking off the diff housing.The amount of teeth are stamped on the crown wheel.17X77=4.53,14X62=4.4,19X72=3.79,19X75=3.95.
