djinuk 2 Posted August 29, 2008 i am after a new fuel line to replace the one on my 205 xs F reg, its a nylon tube, very thin, not sure how thin, but nowhere like halfords sells it, and i really would like to replace it whilst the fuel tank is off the car. Share this post Link to post Share on other sites
craig f90 0 Posted August 29, 2008 i am after a new fuel line to replace the one on my 205 xs F reg, its a nylon tube, very thin, not sure how thin, but nowhere like halfords sells it, and i really would like to replace it whilst the fuel tank is off the car. Halfords should sell it. Any decent factors like motaquip or motormania will to. Failing that a garage may sell you what you need. Share this post Link to post Share on other sites
Goliath 94 Posted August 29, 2008 do you mean the rubber hose? It should be an 8mm high pressure hose. I get mine from halfords, they sell it by the meter. If you mean the (metal?) hose that runs under the car then im not sure where you would get them from. Share this post Link to post Share on other sites
Jrod 7 Posted August 29, 2008 It's not a gti so it doesnt use high pressure hose. Just use some normal 6mm fuel hose. Share this post Link to post Share on other sites
jackherer 543 Posted August 29, 2008 Sounds like one of the breathers on the tank to me, I'm not sure where you would get something similar looking and rated for fuel other than Peugeot but a motor factors should be able to supply something that will do the job even if it doesn't look original. Share this post Link to post Share on other sites
Jrod 7 Posted August 29, 2008 Sounds like one of the breathers on the tank to me, I'm not sure where you would get something similar looking and rated for fuel other than Peugeot but a motor factors should be able to supply something that will do the job even if it doesn't look original. I think its actually the supply pipe hes talking about, they are clear tiny things on base models. Share this post Link to post Share on other sites
djinuk 2 Posted August 30, 2008 jrod has it right , its the fuel supply hose, 6mm you say it is jrod, i went to motormania and halfords , neither interested Share this post Link to post Share on other sites
jackherer 543 Posted August 30, 2008 Halfords definitely have had 6mm ID fuel hose in both low pressure carb and high pressure injection ratings when I've looked in the past. Its very expensive from there though. Share this post Link to post Share on other sites
holland_gt 0 Posted August 30, 2008 Yeah, I'm sure we sell it, not sure on cost though. (I work at halfords by the way) Share this post Link to post Share on other sites
edbar 6 Posted August 31, 2008 Id say try motorfactors until you find one with it in stock, or for the nylon try a plumbers merchants (use similar stuff for oil burners). Share this post Link to post Share on other sites
