tombo
1.9 Brakes 1.6 Hubs
tombo
has anyone fitted 1.9 calipers to 1.6 hubs can this be done with no modifications?
Fox
Yup, bolt straight on with the 1.9 bolts.
Use the 1.6 disks
marc t
And well worth it if your 1.6 setup has that annoying knock whenever you touch the brakes in reverse.
James_R
As covered, but make sure you get 1.9 caliper bolts too as they're much shorter than the 1.6 items and are needed to fit them, saves the headache half way through and finding you can't finish the job :)
