humanz 3 Posted August 14, 2008 When I went searching for a matching connector, the only ones I found came from the engine harness, and of those, one plugs into the fuse board, while the other has a pin-out of Pin1 - 3A Pin2 - 47B Pin3 - 10R Pin4 - ????? Pin5 - 69A Can anyone identify those wires for me so I can figure out what this box is/ does? I've had a search through the Haynes but the print is a bit too fine for me (makes my head hurt worse). Share this post Link to post Share on other sites
Craigb 2 Posted August 14, 2008 47b low coolant sender unit to the instrument panel 69's are to do with brake pad sensors and low brake fluid Share this post Link to post Share on other sites
James Stewart 1 Posted August 14, 2008 What age car is it from? The early 1.6 engine had an oil level sensor, which I think may have gone to a non-descript black box like yours. Bit of a long shot, but you never know! James. Share this post Link to post Share on other sites
humanz 3 Posted August 14, 2008 tom_m said: where was it? It was behind the dash, above the fuse board. I can't tell you the age of the car, unless you can tell from chassis number. It's a mixed up beast....1.9 engine (supposedly) with an early BE1 gearbox, 1.6 brake setup, phase1.5 parts inside and out. Share this post Link to post Share on other sites
Daz_C 8 1 Cars Posted August 15, 2008 humanz said: It was behind the dash, above the fuse board. I can't tell you the age of the car, unless you can tell from chassis number. It's a mixed up beast....1.9 engine (supposedly) with an early BE1 gearbox, 1.6 brake setup, phase1.5 parts inside and out. Its definatly for the oil level sensor. Off an early 205. Tells you via the oil temp gauge IRC your oil level before you start up, Extremely unreliable from my experience. I'd seriously forget wiring that up. More trouble than its worth IMO ! Share this post Link to post Share on other sites
humanz 3 Posted August 15, 2008 Daz_C said: Its definatly for the oil level sensor. Off an early 205. Tells you via the oil temp gauge IRC your oil level before you start up, Extremely unreliable from my experience. I'd seriously forget wiring that up. More trouble than its worth IMO ! Great. I'll bin it. Cheers guys. Share this post Link to post Share on other sites
