malyso
309 Lower Arms
malyso
Do the standard 205 drive shafts need changing to 309 ones if upgrading to 309 lower arms. I.e. are they long enough?
tom_m
can of worms that one :o
run a search and you'll get a pretty even split of people who say you don't need to and other who say you must.
personally i've run 309 arms with 205 shafts on two different 205s without any problems
malyso
thanks Tom may try on standard first then...
pdd144c
I've run numerous without changing them with no problems to report.
AFAIK the only person to ever report serious issues was AndyY
AndyY
Yeah and that was at 2mph on full lock in a car park, the joint on the short shaft popped out and pushed the engine up and ripped the engine mount off on the passenger side, I had run it fine for about 3 months before hand and it could have been just a coincidence.
Jrod
I run the short one with a 309 shaft but the long one is bolted in so using a 205 one.
