S13Nick
1.9 Gti Cam In 8v Turbo
S13Nick
i was just wondering if i would notice anything buy using the cam out of my 1.9gti engine, its the 130bhp engine well thats what mine was rolling road'd at standard!
Probably a lack of power yes...
S13Nick
really would of though it would +bhp! ohwell
tom_m
its got more lift and duration yes, but its also got a lot of overlap, so you'll end up pissing all you boost straight out the exhaust valves. hence the desire for the DKZ cam, which is very similar but with much less overlap.
S13Nick
well ok, i can source a dkz cam, could i swap my 1.9 am in a dkz engine and then he'll see results? as there pretty rare
weejimmy
how do i check if its a dkz engine?
im scrapping 3-4 heads and prob worth a quick check,
you could have it for postage if i have one
Arahan
Dibs on that ^^^^ if you have one then! ;)
sounds of silence
just buy a catcam from qep thats what i went for and are spot on
carbers205
The RFX cam from the 306 xsi 8v is v similar to the DKZ and will do the same job.
Sadly for you I just sold mine!
gizzmo
i have a dkz engine that will be avaliable soon in fact its already out of the car
veloce200
the 1.9 cam is ideal for a turbo it's assymetrically ground and the overlap is on the inlet only so its ideal for turbo engine...
S13Nick
can anyone else prove this as i dont wanna do it to find out that its s**t
sounds of silence
buy one actually ment for that engine there are a few out there that way there in no doubt
veloce200
look at the figures
___________1.6 1.9 Sri
In/opens____8 11.5 1
In/closes____42 43 48
Duration____230 234.5 234
LCA________107 105.75 111
Ex/Opens___40.5 46 43
Ex/Closes__2.5 2 1
LCA_______109 112 111
Duration____223 228 224
i am also using a 1.9gti engine completely standard with a turbo. still not had it rolling roaded yet but I would bet A LOT of money that it would easily produce a lot more power for same level of boost than a 2.0 with the standard turbo cam.
you only have to look at turbo cams to see overlap at tdc on inlet only is the answer if you want more power up top - take a look at www.catcams.be (unfortunately only works with Internet Explorer) and look at some of the wrx cams - look at lca on inlet and exhaust and also lift at tdc on inlet and exhaust. you will see contrary to popular opinion even some lift at tdc on exhaust is acceptable.
