Rich_p 23 Posted July 14, 2008 While stripping my 309 gti today I had my first propper look at the ecu, it has written on it, Pug racing delimited ecu for 205/309 Gti. It does state it's a 1.6 ecu though and the car is a 1.9. Will this cause any issues? Share this post Link to post Share on other sites
Anthony 1,000 Posted July 14, 2008 If you've still got 1.9 injectors and AFM, then the fuelling will be wrong (likely overfuelling as the ECU will be "tuned" for smaller injectors) Share this post Link to post Share on other sites
Rich_p 23 Posted July 14, 2008 If you've still got 1.9 injectors and AFM, then the fuelling will be wrong (likely overfuelling as the ECU will be "tuned" for smaller injectors) Thanks Ant. I'm assuming the rest is as standard still. I guess if my engine is pretty standard a standard ecu will suffice and there is not much point in getting a delimited 1.9 ecu? Share this post Link to post Share on other sites
boombang 2 Posted July 14, 2008 power runs out before the limiter, so not much point removing it as it comes in very handy in cases of throttle being stuck open. Share this post Link to post Share on other sites
Rich_p 23 Posted July 14, 2008 OK cool, I'll have a hunt around for a standard one. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted July 14, 2008 As said you really need the correct one, I beg to differ as mine likes rev's for some reason. Althou pretty much std. But most run out of puff as such quicker than the 1.6's Share this post Link to post Share on other sites
Baz 421 Posted July 14, 2008 One of mine also likes to rev and still pulls up to the limiter, so probably could benefit from having no limiter, or later like the 1.6 at least, but depends what you want to do with it i guess. Share this post Link to post Share on other sites
Rich_p 23 Posted July 14, 2008 it seems to rev readily right the way round, it has a 1.6 box to so not sure if that makes any difference. Either way limited or un limted I need to get me the correct ecu so the fueling is correct. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted July 14, 2008 If you need one drop me a PM, I;ve got a few Share this post Link to post Share on other sites
