chrisj21
Gear Linkage
chrisj21
As title, need some new linkage but cant seem to find them at gsf etc (probably looking in the wrong place)
can anyone help?
thanks
boombang
After all the rods? PM miles
he does a lovely set of ally ones with decent clips to stop them popping off.
Ethos
Yes, I've heard good things about Mile's sets.
I will be buying some when money allows.
chrisj21
Yea i have seen these but wondered if they were more for race than standard road.
I'll drop him a pm
cheers guys
boombang
They still retain the balljoint type setup, so as long as kept clean and lubed they shouldn't cause any issues in terms of premature wear.
Henry Yorke
I have these and they are superb. I have a very firm gearstick now :ph34r:
chrisj21
Henry nooooo! :ph34r:
Will be putting an order in tomorrow on your recommendations.
Cheers guys
MrG
are these relatively easy to fit?
Ethos
Yes, very easy I would say :D
Just need some axle stands / pit and a couple spanners.
Mine even be able to get away without the the axle stands, but it'd make it easier to take the large rod off.
Edited by Ethos
If Henry can fit them, anyone can!!
GLPoomobile
Could Stephen Hawkings fit them?
chocolate_o_brian
lol.
does anyone have a pic of said rods on the car itself? i noticed today while the car was on the ramps (getting exhaust repaired) that there were rods near the gear stick under the car. - think that makes sence :D
sonofsam
I get my rods from the breakers as they are in abundance with non worn cups :lol::)
most of them anyway :D
MrG
thats better, I can see exactly what to do now, thanks for the pic.
chrisj21
Are the rods supposed to be tight on the ball joints? ie no movement by hand?
cheers
Paintguy
Mine were very tight indeed.
Remember, even the tiniest bit of movement in the joint will be magnified in the lever, giving you a sloppy change :wacko:
chrisj21
Thats good then as mine are really loose so good job ive ordered some.
did you think of anything you need Andy for the 205?
cheers
craig f90
Im gonna have to invest in some of these. :wacko:
Just a slight change of topic, There will be a new kit available for the bushes in the 'L' part of the linkage, With this fitted again you gain a more positive and shorter change as there will be zero movement on the 'L' only rotation
I've got these on my GTi with one of the his original modified gearsticks (design since copied by other firms), a group N lower mount & the gear change is fantastic.
No noticable slack & a nice quick shift action plus it make a nice click when changing almost reminiscent of having a metal stick surround (ala Ferrari). :wacko:
Highly recommended.
Graham.
pike_1.9cti
Hi, im in the process of replacing the 2 smaller rods and im stuck on how tight the rods should be. see diagram below
gear_linkage.tiff
many thanks
ps hope you understand what im trying to get at :blink:
Paintguy
I simply adjusted mine to the same length as the original ones. Not sure if that was entirely the correct thing to do, but it worked for me :blink:
pike_1.9cti
I simply adjusted mine to the same length as the original ones. Not sure if that was entirely the correct thing to do, but it worked for me ;)
Was the approach i was going to take and im sure it will be fine, but as like all of us, if i can better it somehow i will :blink:
anyone else know? what difference does it make if it was longer or shorter?
any help appreciated
ben
If you adjust them you change the position of the gearstick, you'll end up with it hitting the seats etc.
IIRC the haynes manual has a method for adjusting them but if you can engage all gears without hitting the seats and with the gearstick in a sane position when its in neutral you can't go wrong really.
