iamjackiechan
Mi16 On Carbs
iamjackiechan
hi
ive got a standard mi16 and want to put it on carbs,
what do i exactly need to do this and should i go for bike carbs
or standard carbs.
cheers
will
Tried the search function?
markw
really helpul reply Baz?
whats needed-
carbs,inlet manifold,throttle linkage and cable,fuel pump,regulator some modifications to fuel lines and wiring etc
and set up on a RR, i ran my modded 8 valve on twin 45 webbers and thought
they were awesome but new ones are very expensive the bike carb route is becoming
more popular know but i dont know how hard it is to get them to fit
:D No you're right, it wasn't at all, neither was it meant to be.
Such information is already on this forum. You just need to look, or sometimes in the case of newbies be made aware of the search function.
Coonper
There was someone on here selling the complete set up not so long ago for about £500?
Yes, i have a set. Dellorto 45s setup perfectly for a 1.9.
iamjackiechan
hi
thanks for the replies.
i know carbs is definately the way i want to go.
cheers
projectpug
I went for what i class as proper carbs weber 45's and i thikn you will be better off with these also the manifold are easier to get hold of and more parts are off the shelf items and not custom ie the manifold for bike carbs etc.
Unless your aiming to do more modifications carbs on their own on a good mi arnt really worth it.
Coonper
Ive got twin 45 dellorto's on my mi16.
Worth it just for the sound i wreckon! :rolleyes:
Supposedly you get a nice power increase too!
