mikebullock84 0 Posted June 23, 2008 like above cant get the new motor in my dimma resto started, checked the fuel pump, and i have no life there, so which relay do i have to replace or fuse? i dont have a manual so i dont know which one is which in the fuse board?! i have a laserline immboliser fitted to the car, coudl this be cutting power to the fuel pump? thanks in advance for any help! Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted June 23, 2008 How have you checked the fuel pump? The relay is located next to the ECU, to the right of the steering column. Share this post Link to post Share on other sites
simonb 0 Posted June 23, 2008 Has to be the relay then as this controls the fuel pump and injectors. Try putting 12v across the pump and seeing if the car runs. If it does, I would get on ebay and get a 2nd hand relay for about £10. Or just try removing any dry solder joints from yours as this is usually what causes the problem. Search google there is a guide for sorting the problem out but you need to be quite accurate with a soldering iron. Share this post Link to post Share on other sites
mikebullock84 0 Posted July 3, 2008 (edited) right ive put a new fuel pump relay on, but still no power to the fuel pump, i just hope ive wired the new motor up correctly!! ive got a lad i know through a friend that is an auto electrican, so hopefully he can make it out soon to have a look at it, and get it going! ...hopefully!! Edited July 3, 2008 by mikebullock84 Share this post Link to post Share on other sites
welshpug 1,722 Posted July 3, 2008 (edited) I had a similar problem and it's the fusebox itself, check the following; check that you have power at the fuel pump when cranking. If not check the fuse, nearest one to the driver in the fusebox, check that you have power to the fuse if its fine. If you don't have power there check wire 32a, big red wire in a 4 wire plug in the middle of the fusebox. I had power here but not at the fuse itself, the circuit from the fuse to fuel pump was fine however! If you still have no power check the relay. Edited July 3, 2008 by welshpug Share this post Link to post Share on other sites
DjB 0 Posted July 4, 2008 Do have an immobilizer hooked up to the fuel pump? I had the same problem and it turned out to be a dud immobilizer. Chris Share this post Link to post Share on other sites
