adamc
4-1 Manifold
adamc
Just bought myself a 4 branch manifold and exhaust system.
Just wondering if there is any useful information i should know before fitting it?
Does the manifold just bolt straight on as a replacement, do i need to get any gaskets or anything?
vickiw106
what manifold have you got
different types have different fitments
adamc
its a magnex 4-2-1 manifold
James_R
You need to fit the up rated bottom mount to reduve engine movement to lessen the chance of it cracking.
Also you may need to move the engine forward slightly to get the manifold down the back of the engine bay, seems to depend car to car.
adamc
ok thanks for that, does the standard gasket fit or do i need to source another one.
James_R
std gaskets fit make sure they're the right way up, easy mistake to make.
slow_matt
I removed the heat sheild, made it much easier.
pike_1.9cti
as above, i removed the heat sheild to fit mine and if you work the angles you can fit it in without having to undo engine mounts to tilt the engine forward
Peetypug
i had a right ball ache fitting mine
had to take top and rear mounts off then tilt and lower the engine :lol:
i couldn't get it to seal properly as the engine kept moving, so fitted a solid rear bush. this made a hell of a lot of vibration and caused the manifold bolts to work loose
so off it came and i got rid of it
adamc
had to take top and rear mounts off then tilt and lower the engine :(
ok thanks for the advice, sounds like it could be an interesting job. Been doing some research into the 4-2-1 manifolds, some people say it does make a difference, but i am hearing alot of stuff about how it doesn't make a noticable difference on the 1.6 engine. Would you guys say it is worth doing?
