dan druff 0 Posted May 23, 2008 hello i have been a member of the forum for a little while but never posted before. so in short i have a 205 1.9 laser green with an mi16 engine fitted which to tell the truth has worn out , so after some searching i have decided to go the turbo route from an 406 sri. engine ,gearbox ,harness,ecu and rads etc have already been purchased and engine has been removed from my 205 i have seen some of the conversions done already on this forum and find all or most have been done to a very high standard, hopefully mine will be of similar ilk, i am gonna try and post some pictures in the next week or so ,and keep things up to date. dan Share this post Link to post Share on other sites
Hardgraf 0 Posted May 29, 2008 Be watching this. Are you planning on doing the work yourself? Tom Share this post Link to post Share on other sites
craig f90 0 Posted May 29, 2008 hello i have been a member of the forum for a little while but never posted before. so in short i have a 205 1.9 laser green with an mi16 engine fitted which to tell the truth has worn out , so after some searching i have decided to go the turbo route from an 406 sri. engine ,gearbox ,harness,ecu and rads etc have already been purchased and engine has been removed from my 205 i have seen some of the conversions done already on this forum and find all or most have been done to a very high standard, hopefully mine will be of similar ilk, i am gonna try and post some pictures in the next week or so ,and keep things up to date. dan Yeah there are some awesome conversions on here. And equally awesome advice. Keep us posted & good luck with it. Share this post Link to post Share on other sites
dan druff 0 Posted May 30, 2008 yes im going to be doing the conversion myself ,got to post some pictures which are still on my phone my 205 has had a previous front end repair which has gone rotten around the inner wing area so i have obtained another 1.6 gti shell which i can get a few parts off and also cut out the area i need from the inner wing. also went to local scrappy and they had a 306 xsi ,so had a result getting the right top mount so at the moment im going to source a clutch , having searched on the forum a diesel clutch seems the best option or does anyone have any other options. Share this post Link to post Share on other sites
sonofsam 5 Posted May 30, 2008 Dan, most of use a Valeo Mi16 clutch for this conversion. I myself have one on my 2.0T and driven 10k road miles with no problems as of yet, just make sure you buy genuine Valeo item. Good luck with your conversion Share this post Link to post Share on other sites
dan druff 0 Posted May 30, 2008 http://s304.photobucket.com/albums/nn179/shay_9_/ not to sure if this link works but here are a few photos so far Share this post Link to post Share on other sites
welshpug 1,626 Posted May 30, 2008 crikey! not see one gone like that before, I'd recommend going to Peugeot for the repair panels, circa £25 for the section you require I think, I really wouldn't weld in old metal. Share this post Link to post Share on other sites
dan druff 0 Posted May 30, 2008 i know it is quite shocking the car has been front ended at some point ,the photo doesnt show how bad the repair is. Share this post Link to post Share on other sites
craig f90 0 Posted May 30, 2008 Dan, most of use a Valeo Mi16 clutch for this conversion.I myself have one on my 2.0T and driven 10k road miles with no problems as of yet, just make sure you buy genuine Valeo item. Good luck with your conversion Thats the exact clutch kit i used too. holding out very well at the moment. at least with having an mi before, you wont need to spend forever looking for a mi16 flywheel. I aint seen a flitch that bad since i repaired a D reg diesel. Share this post Link to post Share on other sites
dan druff 0 Posted June 19, 2008 hi just a quick update been on holiday and busy with work so not a lot done at moment should have some more photos up at weekend . have purchased valeo clutch kit , new gearbox seals and paint and driveshafts overhauled hopefully for weekend cheers dan Share this post Link to post Share on other sites
dan druff 0 Posted July 14, 2008 a few other photos Share this post Link to post Share on other sites
dan druff 0 Posted July 14, 2008 so far mi engine out, turbo engine on stand with head off cylinder head had slight corrosion around head face so have had skimmed all valves have been cleaned and ready to go back in at the moment i am re-tapping all the threads on the engine ready to go back together gearbox has been primed and painted as has engine block gonna try and get rest of photos up this week ,progress is slow at moment but still on going cheers dan Share this post Link to post Share on other sites
dan druff 0 Posted July 14, 2008 (edited) link to other photos is on page one , cheers dan Edited July 14, 2008 by dan druff Share this post Link to post Share on other sites
dan druff 0 Posted August 21, 2008 (edited) hello i have been a member of the forum for a little while but never posted before. so in short i have a 205 1.9 laser green with an mi16 engine fitted . so after some searching i have decided to go the turbo route from an 406 sri. engine ,gearbox ,harness,ecu and rads etc have already been purchased and engine has been removed from my 205 i have seen some of the conversions done already on this forum and find all or most have been done to a very high standard, hopefully mine will be of similar ilk, i am gonna try and post some pictures in the next week or so ,and keep things up to date. dan gonna update very soon as engine bay now painted and engine all together. Edited August 21, 2008 by dan druff Share this post Link to post Share on other sites
leon 1.9 0 Posted August 21, 2008 tasty seats, are they out a different car or did you buy them just for the 205? Share this post Link to post Share on other sites
dan druff 0 Posted August 21, 2008 THE RECAROS WERE IN THE CAR WHEN I GOT IT,MUST SAY VERY COMFORTABLE Share this post Link to post Share on other sites
leon 1.9 0 Posted August 21, 2008 Do you work for Picador then? Share this post Link to post Share on other sites
