josh1990
Problem Starting.
josh1990
Somtimes when i try and turn my car over not a great deal happens when i turn the key, apart from a whirring noise coming from the starter area, i reackon the starter is buggerd but i wanted your opinions, sounds like the starter is turning and not engaging into the flywheel, battery is fine, alternater checked for volts kicking out fine so point me in the right direction on what to do.. Thanks
Josh
swordfish210
Take the starter off and give it a good look over, also check the ring gear on the flywheel.
josh1990
I'll give it a go at the weekend, A new starters 50 quid like so a quick fix would be nice :D
Casanova
Starters can stick - whack it with a lump hammer, this may well free it off in the short term :D
BERTMAN
make sure all the connections on the back are on tight, theres a spade conector and a 13mm nut
