Guest gilou-bilou
Cheap Solution To Fit Carbs With Power Steering ?
Guest gilou-bilou
Hi,
Anybody have a cheap solution to fit carbs with power steering ? I plan to fit carbs (weber or bike) on my rally car, but i have an plates lsd. And i dont want to remove my power steering. Infortunatly, as you can see herebelow, i'am pretty sure to do not have enough space (due to the alternator location):
If anybody have a solution or already done that, please, help me !
PS: Sorry for my english languages
One solution is to drop the alternator down to the non-pas position, then use an electric pas pump from a 106/Saxo.
Richie-Van-GTi
how about use mappable ignition, get rid of the dizzy and stick a pulley on the camshaft to drive the power steering so the alternator can be moved down.
Or put an electric power steering pump in from a saxo/106, even an electric column from a corsa or punto.
Guest gilou-bilou
Thanks, i will try to do something with saxo/106 pump !
Many thanks. Anything special to mount saxo106 pump ?
Guest gilou-bilou
Sorry, i didn't see it before ...
Thanks a lot !
Easy, have a look at this
Just need a alloy sump to fit it
Guest gilou-bilou
Marvelous !!!
Only need an alloy sump ? Really ? I can keep everything stock, pump, and so on ?
Yes you can, On this a 306 GTi6 (S16 167) PAS Pump was used as the pullies smaller and fit's better in the space, The Pipes need adjusting but and specialest hose company can do this, The only part you need is the bracket to mount the pump to the sump which you can get from me
Guest gilou-bilou
Thanks, i will do like that !
I need also to think for new line for my stock oil cooler. The stock ones are exactly where i the new pump location is.
You can provide the bracket ? perfect !
I really start to dream about my engine with beautifull carbs !!!
Guest gilou-bilou
Have a look on that, i found it on my archive ... It seems the guys inverts pump and alternator ...
Thats the Iron block engine so the mounts are all different again
Guest gilou-bilou
Oups, sorry. You are right !
I'm not worried, now with your solution, i have the key the carbs heaven !
